HID defect??
Old Feb 25, 2015 | 08:44 AM
TLIBZ's Avatar
C63 AMG, Camaro SS, E55 AMG, IROC-Z
HID defect??
Hey guys, I have Morimoto XB35 35W 6000k Fogs in my car. The right fog starts up and warms up fine at 6000k, but my left fog starts up at the same color as the right fog (a bit bluer than 6000k), but then warms up to < 5000k. I would say around 4500k, almost halogen colored...
Anyone had this problem before? I'm going to switch the bulbs and see if it's the bulb or the ballast...anyone know if it's the bulb or ballast before I swap em out?
Old Feb 25, 2015 | 09:34 AM
forcefed4door's Avatar
05 E55, 06 Audi S4
Most likely the ballast. But before even asking I would have swapped the bulb and or potential bad ballast with the other side and diagnosed it quite easily
Old Feb 25, 2015 | 10:56 AM
2000UZJ's Avatar
E55
How old is the kit? The ballasts generally do not change the bulb color. They usually flicker or just don't start. The bulb may of color shifted or it's not broken in all the way if new.
Old Feb 25, 2015 | 12:23 PM
20313203's Avatar
2005 AMG E55
I had the Morimoto 5Five kit with 5k bulbs in my 2005 E55 and finally took them out. They were so inconsistent and no one could figure out why. Had a buddy with same kit and had the exact same results.
Old Feb 25, 2015 | 06:50 PM
TLIBZ's Avatar
Well I just took out the bulbs, I believe one is the wrong one. They are both different bulbs. One has a metal piece on the base and is shorter. The shorter one with the metal piece also says "6K" on it and the other one does not...The one that does not is the bulb that is discolored..
Old Feb 25, 2015 | 06:54 PM
islandbeef's Avatar
2012 GL450, 2013 Lexus GS350 F-Sport
Yeah, swap each side and re-check your connections to be sure. Otherwise, you probably have a faulty ballast.
Old Feb 25, 2015 | 09:41 PM
akmatic63's Avatar
10 C63, 06 S65, 14 ML350, 95 S500
well thats awkward.
