HELP!! Timing pull problem
Old Mar 8, 2015 | 08:53 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
I am not sure why or how long this has been happening, but the car should be at 18-20* of timing and is only getting like 6-8.
I just changed the plugs and that didn't do anything. I recently had my supercharger pulley break and had the blower off replacing broken parts, I don't know if this issue came after that or if it has been there for a while since I never log the car. I just dynoed the car, saw it made real poor power and was rich so got a new tune to flash and did logs after flashing a new tune and saw the low timing. Checked with Eurocharged and made sure timing wasn't set real low and it wasn't so something is going on.
Intake temps are only hitting 120s doing a 2nd and part of 3rd log and timing blows the whole time.
Any ideas what could be causing the problem?
Old Mar 8, 2015 | 09:07 PM
Hulk's Avatar
A Merc
Check for anything that can cause a knock,loose parts etc
Old Mar 9, 2015 | 12:18 AM
urbamworm's Avatar
Will have to snoop around in daylight, not really sure what could be loose that would cause something like that.
Old Mar 9, 2015 | 12:23 AM
Hulk's Avatar
A Merc
Low timing like that can only come from knock. When you had the blower off did any of the knock sensors in the valley get hit or something?
Old Mar 9, 2015 | 03:22 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
did you let somebody put low-test fuel in your car
Old Mar 9, 2015 | 06:06 AM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
At which RPMs/Load you see those timing numbers?
Old Mar 9, 2015 | 09:34 AM
chawkins2001's Avatar
2006 E55 AMG
Low timing could also be associated with a hidden shifting issue. Is your car shifting ok, or notice any unsual there?
Old Mar 9, 2015 | 05:48 PM
urbamworm's Avatar
Not that I now of, a friend and I lifted the blower off and put it back in place.
Of course not, but the car has been like this through 2 or 3 tanks of fuel too, so it isn't a fuel issue.
At all rpms, I started at around 2500rpm in 2nd on my last log and went to about 4500 in 3rd. Here is a copy and paste of the log, not sure if it will turn out all jacked up but can probably figure it out.
Time (sec) RPM Load Manifold Pressure kPa Manifold Pressure PSI Ignition Timing Intake Air Temp C Intake Air Temp F
191.95 ___2284 36_______ 103_______0.2___________3____________ 26 _______________79
192.64 ___2670 100_______ 173 _______10.4___________ 3___________ 27 _______________81
193.32 ___3201 100_______ 164 _______9.1___________ 1____________ 29 _______________84
193.99 ___3729 100_______ 169 _______9.8___________ 4.5____________ 31 _______________88
194.68 ___4266 100_______ 176 _______10.8___________ 6____________ 33 _______________91
195.39 ___4810 100_______ 183 _______11.9__________ 7.5____________ 36 _______________97
196.06 ___5325 100_______ 173 _______10.4___________ 7____________ 39 _______________102
196.71 ___5762 100_______ 174 _______10.5__________ 9____________ 44 _______________111
197.46 ___6227 100_______ 160 _______8.5___________ 12____________ 48 _______________118
198.18 ___6630 73_______ 81 _______-2.9__________ 8.5_____________ 50 _______________122
198.89 ___4512 100_______ 182 _______11.7__________ 6___________ 49 _______________120
199.6 ___4649 100_______ 183 _______11.9__________ 6____________ 48 _______________118
200.34 ___4856 100_______ 187 _______12.4__________ 15____________ 47 _______________117
201.02 ___4780 12_______ 23 _______-11.4__________ 30____________ 45 _______________113
As a matter of fact yes it does have a shifting issue now. After the first log I took I mentioned to Jerry that the car was not shifting right now, it shifts fine on the 1-2 but 2-3 is slow and rough and 3-4 takes forever to happen. I wasn't sure how flashing a new tune in would change the shifting but it instantly didn't shift right anymore, I have just been trying to figure out this timing issue that I wasn't even worried about the shifting issue at the moment. Maybe I need to try and get another tune to flash in.
Old Mar 9, 2015 | 05:57 PM
Hulk's Avatar
A Merc
Worm can you do a 3rd gear pull to redline and only have
Rpm
Timing
Boost
Trying to make the refresh rate faster
Old Mar 9, 2015 | 06:04 PM
urbamworm's Avatar
Sure
Old Mar 9, 2015 | 06:30 PM
urbamworm's Avatar
Ok, I am an idiot so log of 3rd starts a little high in the rpms, car kept dropping down to 2nd gear and I wasn't even thinking I was in sport mode and shifting down to 3rd to start the run but didn't have it in manual. Oh well but this is the 3rd gear part of the log.
Time ___ RPM KPA PSI Timing
379.94 4340 119 _2.6 ___12
380.38 4543 185 _12.1 ___6
380.78 4721 185 _12.1 ___6
381.2 4797 182 _11.7 ___7
381.64 4938 181 _11.6 ___7
382.04 5032 178 _11.1 ___7
382.45 5139 179 _11.3 ___6
382.88 5230 179 _11.3 ___6
383.29 5361 179 _11.3 ___6
383.73 5455 175 _10.7 ___7
384.15 5532 183 _11.9 ___7
384.59 5613 176 _10.8 ___7
384.99 5695 174 _10.5 ___7
385.41 5799 174 _10.5 ___7.5
385.84 5853 176 _10.8 ___8.5
386.25 5986 167 _9.5 ___8.5
386.66 6023 171 _10.1 ___7.5
387.09 6101 166 _9.4 ___8.5
387.52 6153 167 _9.5 ___9
387.95 6233 174 _10.5 ___9
388.37 6289 167 _9.5 ___8.5
388.79 6347 167 _9.5 ___8.5
389.19 6381 171 _10.1 ___8.5
389.64 6445 167 _9.5 ___8.5
390.05 6503 162 _8.8 ___8.5
390.48 6551 160 _8.5 ___10
390.91 6574 158 _8.2 ___10
391.33 6632 142 _5.9 ___18
Old Mar 9, 2015 | 07:57 PM
Hulk's Avatar
A Merc
Flash the car to stock tune to take the tune out of the equation an try again
Old Mar 9, 2015 | 08:16 PM
2006 E55 AMG
Also, is your tcu stock.
when you realized this timing issue, what did you change in the setup prior to realizing you had this problem?
Old Mar 9, 2015 | 08:28 PM
urbamworm's Avatar
Problem fixed, I actually decided to flash back to my previous file for when I had the blower pulley and the car shifted perfect and was ripping. Got all my timing back. Something was jacked up with the tune they gave me. I will just have to get back on the dyno now and see how far off the air/fuel is or isn't on stock pullies.
I am seeing 11 and 12psi in the mid range and 8 and 9psi up top right now with weather around 70. Car has stock crank and blower pulley with Kleemann headers (no cats).
Thanks for the help on giving ideas, wish I would have tried flashing back a month ago since I have been dealing with this for a while.
Old Mar 9, 2015 | 08:38 PM
Hulk's Avatar
A Merc
Cool!
Old Mar 9, 2015 | 08:51 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Well by your numbers it shows even with the stock pulley and a tune where you don't dump excess psi you pull good/better boost than stock
Old Mar 9, 2015 | 08:53 PM
urbamworm's Avatar
All I can say is 10 degrees of timing sure dose make a difference lol.
Old Mar 10, 2015 | 08:50 AM
kompressede's Avatar
Sold - 05' E55
Glad to hear this worked out.
Old Mar 10, 2015 | 09:19 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Do you have a STAR unit to hook up and check all your sensors? knock sensor, pinched wire under the blower or maybe even a IAT sensor giving the ecu bad info.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 10, 2015 | 11:29 AM
urbamworm's Avatar
Read my 2nd to last reply. New tune was the issue.
Old Mar 11, 2015 | 01:25 AM
Max.H's Avatar
E55
Love reading threads like this that turn out good. Congrats
