Methanol injection
Me (e55) and a friend of mine (e63 weistec charged) are planning to install meth injection to cool intake temps and not get timing pulled towards the top.
Being in georgia, the actual juice is hard to get and frankly such a pain in the *** that its not worth it. So, if we use medical spirit 96.6% alcohol 50/50 with water what negative effects ar we looking at? Is it gn be bad in any way for the engine? Should we use jsut 100% alcohol or even 100% water just to cool? Octain bump isnt the primary concern ar this point.
Great review there... already with very small injection, a reducing of 33 degrees in IAT. WOW that potential is huge.
Tune needs to be adjusted as they say or we 55AMG users "only" use it for colder IATs?
I run 9:1 distilled water to HEET on a CM10 post blower. The 10% methanol is only used because on the CM10 nozzle, I get a slight bog on shifts... If I pulled the blower and swapped for a CM7, I'd run 100% water
