Part number for tranny valve seals?
Old Mar 20, 2015 | 06:17 AM
1cerberus4u's Avatar
2007 E63
Good morning;
I continue to have challenges with an rpm "flair" in my 2/3 shift and a bit in my 3/4 shift.
While I have not taken the car to the dealer to test the adaptation fill rates (which I understand they can test for) on shift speeds, I plan to do a maintenance run on the tranny
I have been led to believe that the valve seals do wear out and that changing them could make a significant difference.
I have also been told that the tranny valve seals are a specific part number.
Anyone know much about this issue and what the seal numbers are?
Old Mar 20, 2015 | 06:28 AM
cm60k's Avatar
Do you mean small o-rings of shift solenoids..?
ZAYED,,
Old Mar 20, 2015 | 06:48 AM
2007 E63
Zayed;
Honestly I have not looked at a schematic of the tranny (lazy I guess), so I would assume so as these are accessible when you drop the pan?
Old Mar 20, 2015 | 07:00 AM
cm60k's Avatar
Yeah, if it refers to the valve solenoids, pan & valve body should be removed to access them,,
these o-rings not coming separately, they comes assembled with solenoids..!!
ZAYED,,
Old Mar 20, 2015 | 07:23 AM
2007 E63
I do think they are available separately
Old Mar 20, 2015 | 10:47 AM
O-55's Avatar
2005 E55, 2009 VW GLI
I do not believe the valve solenoids are available separately on the 722.9 transmissions. The pressure solenoids are available separately, but the valve solenoids come with the valve body. I'll post a snippet soon.
Old Mar 20, 2015 | 10:49 AM
O-55's Avatar
Here you go.
Old Mar 20, 2015 | 11:01 AM
2007 E63
OK, let me circle back with the source and get a clairification
Old Mar 20, 2015 | 12:48 PM
O-55's Avatar
My mistake. If you look at the part listings, you'll notice that the transmission uses 4 of each (parts 20 and 30). I am not familiar with the 722.9 transmissions. Ask your source what the difference is between the blue and black cap solenoids.
Old Mar 20, 2015 | 03:17 PM
2007 E63
I will ask, but I was told to Replace the 8 Blue seals with this part number: 011 997 1448
Any idea of what they correspond to?
Best
Old Mar 20, 2015 | 04:02 PM
cm60k's Avatar
This seal part # for 722.3, 722.4 tranny, NOT for 722.6 or 722.9..!!
ZAYED,,
Old Mar 21, 2015 | 07:18 AM
2007 E63
And which tranny does my 2007 e63 have?
Old Mar 21, 2015 | 01:33 PM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Any special reason why you would have to use the oem o-rings vs just matching them up to an aftermarket equivalent?
Old Mar 21, 2015 | 02:15 PM
cm60k's Avatar
^+1^,
You have 7G-722.9, what exactly happened to these o rings, is someone cut them accidentally when tried to remove them..??
ZAYED,,
Old Mar 23, 2015 | 06:38 AM
2007 E63
What I am being led to believe is that if a tranny is "flaring" between gears that it could be due to a slowness of fill rates. (which should be checked at the dealer who can do timing check on how long it takes to fill between clutch packs)
He said that these seals are known to wear out and not hold sufficient pressure, which in turn slows fill rates
Thoughts?
Old Mar 23, 2015 | 10:40 AM
cm60k's Avatar
MB guy should not say that, cause he knows these seals not comes separately..!,
i could be wrong, but as i know; the most common of 722.9 are Elc. plate & solenoids failures..!
ZAYED,,
Old Mar 23, 2015 | 11:00 AM
2007 E63
Actually they do come separately as I just ordered a set from the local MB dealer......
If the tranny is "Flaring" on upshifts, do you have any other thoughts on what could be causing it?
Maybe a forewarning of a solenoid going bad?
Old Mar 23, 2015 | 11:15 AM
cm60k's Avatar
That's good, what's the part # of those seals, it will help to know what the issue they referred to..?
ZAYED,,
Old Mar 23, 2015 | 11:34 AM
2007 E63
011 997 1448
Old Mar 23, 2015 | 11:39 AM
cm60k's Avatar
Andy,
Did they say this # is capable to your solenoid..?, how many piece they required..??
ZAYED,,
Old Mar 23, 2015 | 11:48 AM
2007 E63
They did not say specifically, but only to the suggestion that I replace the seals, as that may be the cause of my "rpm flare" between shifts.
You would need 8 of the seals, or so it says...
Old Mar 23, 2015 | 11:50 AM
cm60k's Avatar
I see& good luck,,
don't forget to keep us posted..
ZAYED,,
Old Mar 23, 2015 | 11:51 AM
2007 E63
Will do!
I also plan to bring the car into the dealer and have them check for the adaption fill rates to see if it changes
Old Mar 23, 2015 | 12:34 PM
cm60k's Avatar
Good Move..
ZAYED,,
Old Mar 23, 2015 | 02:31 PM
2007 E63
My guy says to seals for the 7 speed are not available, so they did the work to make sure these fit, which he confirms they do
