*NAME YOUR BEST 180MM CRANK PULLEY*
Yeah u are confused about that second part. The Pistons/rods accelerating the crank does not apply the force in the same way as a twisting motion like holding it from the he other end of the crank.
we can agree to disagree about it...
Their website states that the balancer is designed and manufactured specifically for the M113K rather than from universal balancer/OEM hub which I believe the ASP is?
The price difference is negligible between the two options (both expensive) so I want to get one that will last and handle 600+bhp.
* Hard Nitride coated hub, * Hardened Chrome moly CNC machined steel balancer hub VS competitors mild steel hub. * SFI approved harmonic balancer * Ultra strong, interchangeable, and hard annodized aluminum boost rings. The UPD high performance balancer is precision CNC machined in the USA and installs directly in place of the factory unit. The balancer and crank ring assembly weighs only 12lbs, compared to 15lbs lbs for the factory steel unit.
The ASP is new from ASP. I assume this means a new core??
Assuming the ASP is constructed from a new core, are the extra $'s justified over the UDP?
