*NAME YOUR BEST 180MM CRANK PULLEY*
Old Apr 3, 2015 | 08:31 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
tell me in your opinion the best 180mm CP is.
weistec ? evosport ? Ec?
another question is ...do all 180mm cp makes same power ? if I were to swap say ec to evosport would I need a re-tune?
Old Apr 3, 2015 | 08:37 PM
Hulk's Avatar
A Merc
180 is 180
Best IMO is ASP pulley
Old Apr 3, 2015 | 08:42 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
I would go ASP or Sharduls pinned pulley. I would pin the ASP just for piece of mind
Old Apr 3, 2015 | 09:21 PM
forcefed4door's Avatar
05 E55, 06 Audi S4
My car is around 60k miles on the evosport 180.
Old Apr 3, 2015 | 09:43 PM
GregMB's Avatar
Originally Posted by Hulk
180 is 180
Unless it's built off a non-harmonically balanced (preferably MB OEM) core....
Unbalanced pullies are false economy.
ASP is a really nice one. The new aluminum outer ring designs have 6 locking pins for absolute strength.
-G
Old Apr 3, 2015 | 09:45 PM
Hulk's Avatar
A Merc
Yes, asp can use your mb core
Old Apr 3, 2015 | 11:03 PM
Dat Boy I's Avatar
06 e55
Asp with zero issues 3+ yrs runnin the beast.
Old Apr 3, 2015 | 11:43 PM
m3j0n's Avatar
W220 V12TT Land Yacht / W211 E55 Estate
this is my next mod. Does asp make a 185mm?
I hope their pullies are better then their website LOL.
How do the locking pins work? I thought there is just one bolt that holds the assembly on.
Old Apr 3, 2015 | 11:46 PM
dchl21's Avatar
anyone has weistec ? any belt problems on any of these?
Old Apr 4, 2015 | 07:49 AM
Hulk's Avatar
A Merc
Yes asp makes a 185. Mine has one bolt. Been on since before I bought it. Install is very important on crank pulley.
Old Apr 4, 2015 | 11:39 AM
m3j0n's Avatar
so what is the 6 locking pins that is being mentioned? What exactly is the special install on the crank pulley? New bolt, obviously, but what else?
hulk, which size ASP are you running?
Old Apr 4, 2015 | 11:54 AM
Hulk's Avatar
A Merc
Nothing special about it, just got to install it right. Majority of pulleys that fail is because of bad install. Use someone who has done many crank pulley installs
The bolt should be torqued to 200nm(148 foot/pounds) and wait for 20-30 minutes then the bolt is turned an additional 90 degrees to lock/stretch it.
Make sure it's aligned with the keyway because if it's not you will lose that pulley.
Use a brand new bolt
The keyway can be shredded easily and then you can be in trouble.
Old Apr 4, 2015 | 12:00 PM
m3j0n's Avatar
Thanks for the tip!
where did you have yours done?
Old Apr 4, 2015 | 12:12 PM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
I got lucky and scored an MKB for $500 as it was their last one from old stock. It uses the oem harmonic balancer same as asp.
The oem bolt is a one time use but there are hex bolts available now (for 3 times the price) that can be torqued even tighter and are reusable.
Old Apr 4, 2015 | 12:13 PM
Hulk's Avatar
A Merc
Mine was done by Wade at European specialists in Wellington from the previous owner. Many guys have gone to him for crank pulleys and never problems. He was a master tech and foremen at a Benz dealer then left and opened his shop years ago. He still gets calls from dealers to help with certain problems.
Old Apr 4, 2015 | 12:17 PM
m3j0n's Avatar
sweet... can I use you as a reference?
Old Apr 4, 2015 | 12:20 PM
Just don't make him angry - you wont like it when Hulk gets angry...
Old Apr 4, 2015 | 12:23 PM
m3j0n's Avatar
LOL....
Hulk's Avatar
A Merc
lol
Pm me m3jon
Old Apr 4, 2015 | 12:58 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
ASP 185 here as well and what Hulk says is the ABSOLUTE TRUTH!
Old Apr 4, 2015 | 02:10 PM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
As these cars get older and have more miles be cautious of building an ASP pulley from a high mileage core.
Old Apr 4, 2015 | 02:17 PM
Toadster's Avatar
2005 E55 AMG
one that doesn't fall off
Old Apr 4, 2015 | 05:54 PM
draggbody's Avatar
2005 e55
i have the 180mm UPD pulley and crank extension from shardul... i had previous pulley failure so i sent my crank to BIP for repair and install the crank extension as well as do a full length keyway... i have put 2500 hard miles on the car since i reinstalled the crank and just rechecked the torque on the ARP bolt, still at 250ft-lbs... i will say that i will never recommend holding the balancer to torque the bolt... i built a tool that bolts to both of the torque converter bolts and interferes with the oil pan, it takes probably 15 minutes to recheck the torque on the bolt...
you can see the orientation on the block here
Old Apr 5, 2015 | 12:48 PM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Brilliant! I like that system much better.
Old Apr 5, 2015 | 08:53 PM
Shifter's Avatar
E55, SL63, ML550
Why would you say that? I think that would be much better than transferring all that twisting load through the crank like your tool does.
