what will u guys go for next mod?
Old Apr 9, 2015 | 01:24 AM
E55amgsd's Avatar
05 e55 amg
Alright im in need of more power lol just dont know what way to go.
this is my set up as of now.kleemann mid length headers then xpipe straight all the way back, no mufflers,ftp heatexchanger,83mm s/c pulley with eurocharged tune,colder spark plugs .
what would be the next step ?
maybe a 172mm crank ?
beltwrap kit ?
550cc injectors ?
Is anyone running 172 crank and 83mm s/c pulley ?
thanks alot guy's .
Old Apr 9, 2015 | 02:17 AM
T9ja's Avatar
2005 E55 amg
I just got my ASP 172 mm c/p. Will install it before the week ends. I have also ordered for a split cooling system. My list of mods are listed on my sig.
Old Apr 9, 2015 | 08:36 AM
Hotsauce55's Avatar
2005 E55
Throttle Body
Old Apr 9, 2015 | 09:04 AM
Hulk's Avatar
A Merc
If you go bigger pulley then you need better cooling and then possibly injectors and rail, so as you see no mod is alone it always comes with something
Old Apr 9, 2015 | 09:10 AM
vietjdmboi's Avatar
'04 E55 AMG
TB or 77mm clutched pulley
Old Apr 9, 2015 | 10:11 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
3000 stall Converter should go on before spending bucks on a 82mm TB and the 15 hp gains from it. 3000 stall is still one of my favorite mods and is a blast when you lay into the throttle.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Apr 9, 2015 | 12:47 PM
mobhouse's Avatar
Mercedes E55
My mods are pretty similar to yours and after talking to Jerry from EC, I've decided Trunk Tank, 550cc injectors, 168 in that order.
Old Apr 9, 2015 | 06:41 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
If you went with a 168mm crank pulley you would be slightly above rpm/boost as a 180 crank.
That's as big as you should go without injectors/rails. It sounds like your going bigger in the future so I would do the fuel upgrade first then go for a 175mm+.
Throttle body would be nice also..
Old Apr 9, 2015 | 07:10 PM
E55amgsd's Avatar
05 e55 amg
Whats that bro 3000 stall ? Never heard of it lol
Old Apr 9, 2015 | 07:11 PM
E55amgsd's Avatar
05 e55 amg
168 crank??ill look into the trunk tank amd see if I would go the same route thanks
Old Apr 9, 2015 | 07:13 PM
E55amgsd's Avatar
05 e55 amg
I see this seems like a better decision to go with the biger crank and fule injectors !thanks
Old Apr 9, 2015 | 07:17 PM
E55amgsd's Avatar
05 e55 amg
So who sells the split cooling system ??I seen one on youtube is that the same thing ..supposedly we will.need a bmw res?,should I follow that or na ?
Old Apr 9, 2015 | 07:29 PM
99lightning's Avatar
99 ford lightning
stall is super fun, unleashes the power you already have if your a drag strip guy it will take super prep and real tires to hook. On the street it will be a animal.
Old Apr 9, 2015 | 07:48 PM
sircl55amg's Avatar
2006 cls 55 amg
trunk tank is next
Old Apr 9, 2015 | 08:30 PM
menace2sobriety's Avatar
2004 E55 AMG
With the high stall, I know a TCU tune would be the cherry on top for it but how are they without a TCU tune, is drive ability still really good
Cheers
Old Apr 9, 2015 | 09:28 PM
E55amgsd's Avatar
05 e55 amg
Ohh nice that means way more torque right. How much is the increase on the stalls ?do you know where I can get one ?
Old Apr 9, 2015 | 09:31 PM
2004 E55 AMG
Eurocharged and BIP have them for sale ~$1000, plus I am sure there are other vendors out there that are stocking them
Old Apr 9, 2015 | 09:42 PM
E55amgsd's Avatar
05 e55 amg
Not bad at all man I want to see how much will the increase be ...
Right now im almost pulling the trigger on 172 crank 550cc injectors and a belt wrap kit ..then I would get the stall I did some research and it seems to be a good must mod lol
Old Apr 9, 2015 | 11:12 PM
mobhouse's Avatar
Mercedes E55
yea 168 crank will be safe for me and be enough boost. The trunk tank helps with cooling. Did a few dyno runs and at the end you'd see the heat soak. The trunk tank helps A LOT.
Old Apr 9, 2015 | 11:44 PM
T9ja's Avatar
2005 E55 amg
I thought with more boost, you need more cooling, and with more air you need more fuel?
Old Apr 11, 2015 | 12:36 AM
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
Killer Chiller . Keep all the power you are making with no heat soak.
Old Apr 11, 2015 | 12:29 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Wavetrac LSD...
Old Apr 18, 2015 | 08:16 PM
E55amgsd's Avatar
05 e55 amg
That's your next step ??humm might look into that ..bro but we will need better cooling mods right ??
