Fuel pump and filter assembly replacements
However, what they do is get new adapter wiring harness that connects the new fuel sender (driver side) to the factory harness that is on the chassis because it is a different design. The passenger side fuel pumps get a new adapter harness to replace the existing because some cars burn up the connector. But if you are ordering,using or getting new pumps, chances are they the new ones that I have tested that are not performing well so far on about 8 cars so far. Too many to be coincedence. Also,I bought new ones for my car and still same issue. I am sure some are working ok, but You wont know until you do a fuel pressure test. I wasnt running lean on the lower rpms at WOT until 4500 to 6700 rpm. that was very scary. Like I said, many did not know they had issues. I have measured the new pumps and will attempt to run AEM 320lph pumps. They will fit in the stock location with some minor modification. But if you have the older pumps, it is different. The older style pumps have a return line that splits into a y and dumps back into both fuel pump buckets to the botton siphoning part of the modules. The new ones do not have those y return lines. It only literally has one big return line and a very tiny one that only dumps into one fuel pumps bucket not to the other side like the older ones did. This help distribute the fuel better when the pumps were at max flow to support WOT conditions. It is a new design that is suppose to help prevent the fuel sender side from building pressure and leaking like the old design.
But I think what is happening is that the pumps are sucking up so much fuel from the buckets under WOT in the new design that the return lines are not dumping fuel back fast enough like how the old pumps did. You would think that the buckets would have ton of fuel in them because it is submerged in fuel. But the old design is much more balanced as far as that part.
Yeah not important about how it is done. Everyone I know has had the whole tank done like you, including myself. I just hope these cars I tested have a faulty batch or something. Because I know it has nothing to do with age. 2 cars I tested had them 2 weeks prior to me testing them.
211-470-00-00 Fuel Delivery Module (dual pumps) $411
211-470-64-94 Tank Inner Module (actually filter/regulator) $489
211-471-05-79 Fuel Sender Seal x 2 $34
211-440-05-07 Cable Harness adapter for filter/regulator $15
211-540-07-00 adapter cable to fuel pumps $15
The latest fuel sending unit (dual pumps) will NOT connect to the two earlier fuel filter/regulator versions due to different fuel line connectors.
Your number has a typo in it (50-94 should be 51-94) and is the 2nd version; the part number above is the 3rd version. (EDIT: EPC shows the car is European market and the data card shows the car to be an Australian version; the part number is a 50-94. I stand corrected.)
If you use the earlier pumps, you must use the earlier fuel filter/regulator. If you use the above dual pumps (00-00), you MUST install the adapter cable (07-00) to the fuel pumps; if you fail to do so, one pump runs backward and your fuel pressure will be insufficient at full throttle. Both pumps should run at a~12-13 amps each; if one is at 12 amps and the other at 3 amps, it means someone forgot to install the adapter cable or a previous owner switched pins because he/she was not aware of the required adapter cable.
To add to the confusion, the first versions of the fuel pumps and the filter/regulator were both named "Delivery Units". The titles above are the latest in the EPC.
I'm guessing the cable harnesses 2114400507 and 2115400700 aren't required with the latest non pzev sender 2114705094 and the older style pump 2114701794? I'll have to figure out how to check the amps.
supreame- Is the wiring adapter just for the fuel pump (right side) or is there one for the sender assembly (left side) as well? I specifically mean for the one electrical plug version like you have, not the one with the black external sender unit.
Pumps for using with the single electrical left side sender assembly should be 211-470-17-94, got it. Seems the part number for the fuel sender assembly (left side) is 2114705094 and available and I assume the hoses will be compatible (ie not the ones with the black 90 degree fittings)?
I am considering bending over for the dealer on this one but I would prefer DIY if I can. Being around the other side of the world I would like the best chance of getting the parts right the first time. Thanks for any advice, this is more confusing than it should be.
https://www.dynotunenitrous.com/stor...?idproduct=130 should do the trick.
I also have the adapter for my fuel pressure gauge on the way so I can guess the pump/filter health a bit better.
