Track Day - E55
Thanks! those downshifts in that vid weren't my best, I was wearing my sneakers because I always forget to put on my piloti so my blips were a lil off
can't wait to see more vids!
To All Who Track Their Car
This package allows C63 owner to upgrade their 360/330mm 1pc rotor to 390/360mm RB two piece rotors, still cut down a lot of weight.
Package includes brake pads (option for track compound), stainless brake line, Motul or Castrol SRF brake fluid, everything you need for track activity in a package.
Get some NEW rotors, please dont waste money on cyro or slotted/dimpled/drilled rotors, as NO one in the racing circle uses them.
Drilled are my favorite as they ALWAYS crack around the holes after a hard track day.
But by ALL means at least by EBC red pads, aka street/track.
If you really have the bug, try yellows, or Hawk or pagid RACE pads.
Just dont let friends drive on them, as they take some heat before they stop.
Not really that bad, but the first couple of stops are a longer distance.
To alleviate the brake issue...I ran Porterfield R4S pads with Castrol SRF brake fluid with 2 piece rotors. I was able to run 5+ laps on multiple sessions throughout the day with NO fade what so ever. Having coilovers and R-comp tires helped out the car A LOT as well. A rear seat delete as well as having a CK bucket seat helps shed some weight.
Great runs!
Don't mean to highjack your thread but it's super nice to see other 55K's running their cars at the twisty track.
It's a pretty fun car the blast around the track in. I'm not sure why I enjoy it more than anything else I've tracked but I will admit...it hits the spot. I would like to lose weight but it's my DD and ditching the seats would not go over well. Moving to a lighter rim would help. Handling is a bit soft but I can't really complain. Sport II and lowered 1.75" make it pretty flat around the corners. My favorite thing is 2nd gear 5-6,000RPM and pin the throttle in manual mode and shift right at red line and the torque in third is just stunning.
Great runs!
JK my friend, but serious tape on the headlights? They are cheap afterall, well okay somewhat cheap these days
I would go to rockauto and see what they offer for the 55. Just keep in mind, the rotor for the car at that weight is simply too small for track events. As such whatever you buy will fry.
IF you are serious, remove the fog lights, and buy maximum motorsports universal brake duct get. It gives you generic scoops, duct tubing, and caliper mounts, that you WILL have to modify.
Best of my knowledge, NO ONE builds MB cooling duct kits for the brakes. Maybe try Kleenman, or Rentech. Evosposrt did for awhile but they are history.
As BB said above, get some R type tires, think treadware less than 60 and REALLY let the fun begin. With R tires you will drop on average 2 seconds a lap, aka MORE FUN.
For a heavy car, stay away form Hoosier's. You will eat them up in one event.
Kuhmo Victoracers are a great choice for a tank like ours, LOL
This set up will substantially increase the thermal capacity of your brake while still save you tons of unsprung weight comparing to stock 1pc with smaller size.
Not only this will update your brakes to the newest models it's deemed to be the fundamental solution against any potential brake issue than other attempts being discussed here.
Great runs!
more amg track photos!!!
But please don't go on about weight savings on rotors in a 4400+ car.
AsI explained to Evosport about their carbo fibers rotors, Michael Schumacher would not be able to tell the difference.
An for Heavens sake, please don't try that 4:1 theory on unsprung weight. It has been done to death with NO results.
Thanks again for another product/choice for the MERC crowd!!
I am about to order 2-pc Girodisc for the rear as the fronts are in great shape. I plan on running Carbotech XP20's upfront and XP10's in the rear with a much better fluid.
