Restrictive supercharger??
Why does the bottom of our supercharger have have that V part blocking the outlet? I would think cutting that all out would improve air flow very well no? I read some where that this was for noise...to quiet the supercharger down with its whine but cant seem to find that again. Anyone remove that part?
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Uh, no and don't. It's a v because of the twist of the rotors. Notice how the rotors line up with the v? It's to seal that chamber of the supercharger. The slots/holes next to the v are for noise. If you cut it out you would produce no boost so I guess it wouldn't be restrictive to your belt drive
The V find blocking the inlet is there on purpose. It actually improved performance, but the specifics of how I can't remember (I read an article and it explained why)
PLATINUM SPONSOR
There is a post on porting the blowe going back about 5 years. I think the tittle was from shock to Awe. It is a classic all time informative thread.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Finny's "Stock to Awe" Thread was awesome. That guy was way ahead of the curve with these cars.
Great read!
https://mbworld.org/forums/w211-amg/...stock-awe.html
