Engine bay tank...
Old Jun 7, 2015 | 12:39 AM
b0kix's Avatar
Engine bay tank...
Who is running a engine bay tank here ? Since I installed mine nothing but high IAT , I am only running single pump I think to relocate it in the trunk and add extra pump , I don't think a single pump can keep up my IAT whee high as 195 deg passing the 1/2 mark at the last wanna go fast event.
Old Jun 8, 2015 | 12:55 PM
jmb614's Avatar
E55 AMG
195? Sounds like either your pump isn't working, there's a flow issue, or both.
Old Jun 8, 2015 | 01:14 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
^^^^^+1
Tell us how you bled the air out of the IC after you had the circuit open.
Oh and refresh us on the "wanna go fast" is that 1/2 mile or one mile WOT?
Old Jun 8, 2015 | 10:23 PM
b0kix's Avatar
Pump is brand new and is working not sure what's going on I belive the way the tank sits in the engine bay one pump might not just be enough for some reason it keeps cathing air. I did bleed the system. 3 times so far. I think adding a extra pump would be the goal. Wanna go fast is 1/2 mile event from a dig.
Old Jun 10, 2015 | 11:12 PM
First check the wiring +,+ & -,- to make sure the pump in not running backwards.
Are you saying after you bleed the air out, "later"you are finding more air?
Tell us what procedure you use to bleed the intercooler.
Two pumps is the goal? then pick a good one here VVVVVVVVVV
https://mbworld.org/forums/m275-v12-...ion-pumps.html
Old Dec 25, 2016 | 02:32 AM
khalid janahi's Avatar
W211 E55 / Ws6 Procharger
sir
I have the bay tank same as you, and my IAT is so high so what was solution ?
Old Dec 25, 2016 | 01:49 PM
BoostedAero's Avatar
2004 E55
Engine bay tank looks good but is it functional?
For what it is worth, I am not a guru, but more of a forum stalker for pre-mod advice and analytics
I read a thread that stated that the feed for the engine bay tank was a bad design, when at WOT the acceleration starved the feed circuit and basically ran it dry due to the feed being on the front side (radiator not firewall) of the tank... logically it made sense. But like I said what do I know
I think the tank mentioned was an FTP tank.
195 sounds crazy high fwiw too talk about no boost if still clutched
Old Dec 25, 2016 | 07:58 PM
BlackHammer's Avatar
2006 E55
spot on. I had my return line moved to the back of the tank and front return line capped.
how long have you had the set up? Some guys have had FTP build it with the return line in the back OR had an inlet return built into the tank that runs horizontally tied a back corner.
also, buy a vrp superflo pump ($250) and have it set up to run whenever they key is in ignition.
so, have the FIC done asap and while you are at it add water/meth Injection. JMB614 and Hulk have state of the art set up and I copied SeanO with a fairly inexpensive snow kit.
IAT on a 58 degree started at 48 (I have a killer chiller) and ended at 63 on a 40-130 pull.
Old Dec 26, 2016 | 02:01 AM
I use a ftp tank I datalog and monitored my IAT and at full throttle pull at 3rd gear my IAT went from 99f to 199f, that made me crazy I know fixed 77m pulley its make it worst, so the next day I drain the water and try it with IC cubes and datalog IAT was from 99f went all the way back to 65f with 3rd gear pull went to 119f. but it wasn't enough by using ic cubes it wont stay for more than 2 hard pulls and the 3rd pull my IAT jumped to 155f.
my next plan is
new IAT sensor
dyno, 1- pull with water
2- pull using dry ice
it may be stupid Q to ask what is the difference between feed being on the front side or back side at the end the suction water will be by pump. feed me with any best options I really want this bay tank to work better.
Old Dec 26, 2016 | 02:21 AM
can you give me some advice Im using bay tank from ftp and 77 fixed pulley my iat hit to 199f with some hard pulls,
what can I do to the tank to make it better and why.
Old Dec 26, 2016 | 07:11 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
When you punch it, all your water is pressed against the back wall of the tank. Find a way to draw it in with your pump. I would get a large pickup tube welded in that reaches to the back. Then send the bill to ftp.
Old Dec 26, 2016 | 07:14 AM
got your point, and today I will strat to fix it,
FTP that's the last business with them.
Old Dec 26, 2016 | 02:48 PM
99lightning's Avatar
99 ford lightning
total waste with that ftp tank my little cobra tank has no issues pressure is constant on the pump so it doesnt get air bubbles. Just wish it was bigger.
Old Dec 26, 2016 | 03:02 PM
sir what is you mods and how about IAT ! Is it lower than90
My fixed pulley is driving the iat all the way up.
Old Dec 27, 2016 | 04:44 AM
99 ford lightning
stock pulley that was stock heat exchanger at the time split 03 cobra tank 46deg rise in the quartermile so at the end it was 109deg. On the dyno 27deg rise ended at 90deg. I was in the 150deg act range with ftp tank and aftermarket heat exchanger before the end of the quartermile.
Old Dec 31, 2016 | 08:12 AM
cij911's Avatar
one car at a time
I too run the cobra tank and keep contemplating adding a large (5 gallon) tank in the trunk and a killer chiller....The FTP tank had some issues that I highlighted a long long time ago.
