Adding 12V power in the center console
Old Jun 24, 2015 | 10:41 AM
ekalb's Avatar
05' E55 Wagon, 18' S90 T6, 00' M5, 19' F150
I have searched all the DIY stickies and haven't seen what I am looking for. I am sure by now someone has added 12v power to the cupholder area under the sliding armrest door, but I am having no luck finding a thread on it.
I am looking to add a usb power source in that area and figured tapping into the 12v supply behind that console may make sense. My car is pre-wired for some sort of state of the art phone back in 2005. Maybe there is a way to use that harness to add power?
Right now I am just running power with a 3' cord up from that rear 12v in the ashtray, but I would like a more permanent (clean) way of getting it in the cupholder area.
thanks in advance for any idea on this.
Old Jun 24, 2015 | 10:53 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
cigarette lighter
Old Jun 24, 2015 | 10:59 AM
ekalb's Avatar
Originally Posted by shardul
cigarette lighter
I don't want to run cords all over the place which is what I am doing now. I also, don't want to have either of the ashtrays open in order to run cords out of them. I bought a basically flush mount usb supply for the cigarette light area and even with that I couldn't close the ashtrays.
Old Jun 24, 2015 | 11:29 AM
shardul's Avatar
that is what i meant get the 12v supply from the cig lighter harness
Old Jun 24, 2015 | 11:30 AM
Rocman8's Avatar
E55
He's saying to tap into the cigar lighter wiring under the console.
Old Jun 24, 2015 | 12:20 PM
Denroll's Avatar
'06 E55
I bought the stuff to do this. I got a 12V power source for use on a motorcycle. When I finally have to take the dash apart to replace the vent door/flap stepper motor, I am going to tap into one of the keyed 12V sources and run it into the console. I might even get crafty and install a retracting cord system.
Old Jun 24, 2015 | 12:31 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
you may want to try something like this that has the DC-DC power supply built in. http://www.ebay.com/itm/Marine-Caravan-Dual-USB-2-1A-Port-Socket-Charger-Cigarette-Lighter-Flush-Mount-/221808130372?pt=LH_DefaultDomain_0&hash=item33a4cb7944
wiring to the Cig lighter as Shardul suggested is a good way to go. The A34/15 Ctel connector/wiring that you mentioned is not worth messing with (for your power)
Cheers,
Chris
Old Jun 24, 2015 | 12:40 PM
or if you wanted something a little cleaner, you could go with something like this
http://www.ebay.com/itm/Dual-2-Port-USB-for-DC-DC-Car-Converter-12V-To-5V-3A-15W-Power-Supply-Adapter-/261942456546?pt=LH_DefaultDomain_0&hash=item3cfcfcb0e2
and use the usb coming off of it or use a panel mount USB like I did in my SL55 (see pic)
Attached Thumbnails Adding 12V power in the center console-20150528_213852.jpg
Old Jun 24, 2015 | 01:12 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
You can also "switch" the cig lighter's fuse to "switched with key" or "always on"
Old Jun 24, 2015 | 02:18 PM
JoeNobody's Avatar
Mercedes
check clearances when installing, it's really tight in there. When I installed a usb port the power circuitry pinched a canbus wire on another wire bundle.
Old Jun 24, 2015 | 03:54 PM
ekalb's Avatar
How do you remove the rear ashtray? I poked around there for a second, but it wasn't obvious to me.
Great ideas! thanks!
