How do I bleed both coolant systems once split?
A more important question is, how are you bleeding your split system? Unless your pump runs all the time, (early MY cars), you'll have to jump power to it, or activate via STAR.
(I guess you could try to drive with a hose from the bleed point into your tank, but that would be a little tricky)
I don't think that's ever been confirmed, but there's still a good chance that the pump will run. You can just try it I guess.
Again, I think you can assume that the other side of the system will bleed itself. Just drive around, and keep an eye on the temperature.
Does anyone have any facts about how the IC pump turns on? Some say its on all the time some say it activates when supercharger is engaged.
Does the year matter? Any hard facts?
I always know when my pump is on because I have a small led light wired in that is on the dash......light on ...pump running. The pump will never turn on if I drive real easy but as soon as I give it more than 30-40 percent throttle it comes on and will stay on.
Bleeding by jumping ic pimp fuse
First please remember when all you do is giving the IC it's own refill point ok so when bleeding after split do it into the new tank not over in the old.
I always just jump the pump at fuse easy in the trunk fuse in the side it is the relay that sits at the bottom there is nothing after the pump relay easy to find. Works every time and no key in ignition but be careful not to damage use both hands
let pump run 20min before I was fully happy and with a new super highflow pump damn that is good stuff
