Real world IAT"s
Real world IAT"s
What do you guys see for IAT"s in the 80-90 degree weather with an aftermarket cooler. I am seeing around 125-130* with good pulls in 3rd gear. Is that about right? Normal driving it will hover around 85-90* ...same temp as outside air.....lower 80"s if I cool the engine to 185 while driving with the cooling fan over ride. So I am seeing a 40 * increase in air temp.
Exhaust only..headers, no second cat or resonator,johnson pump, boxed in intercooler and closed loop system. Also not that it matters but fuel rail work and in tank filter delete. AFR hovers at 10.8.1 on pulls.So nothing special really.
