E55 advice needed!
1. It's going to be out of warranty that's for sure, no e55 at this point carries a warranty, is it suicide to own on after warranty? Or is it somewhat manageable?
2. Is there anything specific I need to look for when purchasing? I know the that some of the 08-09 (I think) e63 and c63 had headbolt issues, are there any issues like that I have to watch out for in the E55?
I would love some feedback! Thanks guys!!
95,000 miles on the ODO, I've tracked it, slid it, launched it and modified it quite a bit (not like some on here, but modified...) and never had any catastrophic issues. I had a few issues that became annoying and a few break downs but no major $$$$ repair bills.
It won't be suicide owning a **CLEAN** E55, but buy one that has been beat on and you will have issues. Mine was a very clean car with a lot of maintenance. The only issues I've had are the ones that I have created by modification/track days.
These cars love to be driven hard, and they really love being maintained.
Also, to answer question 2... you might want to know whether or not the SBC Unit has been replaced, the fuel tank/sender units, and the status of the airmatic!
- CPS (crank position sensor) just changed 2 months ago.
- Transmission conductor plate
- Voltage regulator
- IC Pump
- Water pump
- Airmatic suspension
Thank you for the input mkiv!
Dealer just try to make AMG owner pay extra but in fact they are the same.
Oil change they will charge you much more compare to E550 or E500 but basically use the same oil. You should find a good indy shop for your cars. My oil change is $100 with Mobil one, dealer will charge you $150+
And those C, D, E service is just pure scam ! They only do inspection not actually fixing or repair anything. Instead just change all the fluids, belts would cost less than E service in Dealer. With $25K you can find a low mileage and very clean E55 today. Good luck with your search !
