Programmable tcu for factory cars with a 722.6
https://mbworld.org/forums/w211-amg/...63-vs-e55.html
Of course, the rumor has always been that the 7G couldn't handle the torque, but who wouldn't want to try?
When I get the wheel speed sensor data sorted it will just be a matter of tuning for the cars. Which should be fairly straight forward.
As far as the 7g transmissions. They are mechatronic. And to use mechatronic transmissions we do something very different. We use a module to either translate the data on the CAN bus or emulate what needs to be there so the factory tcu will work as though it is in its normal environment. The problem with doing this in the 7g is that it has drive authorization the same as the factory ecu. So it will not work with out the correct hash from the EIS. It might be possible to put a 7g into a e55 since they did come in a me2.8 equipped w211 and w219. But coding it to have the right tune for proper function would be something a tuner would have to do. There would be no way of getting a scn string for the e55 from Mercedes. It is not impossible just going to be difficult and probably will never happen for the 2-3 people that might be willing to pay for it.
Do you have a link to the car you're talking about? I'd like to read it.
Again that is just part of the problem. The tcu has to have the correct tuning in it to handle the power and the only way to get that, atleast that I know of is to have an used unit and get it unlocked. Like I said maybe a tuner could dump a file in a tcu for you.
But this is a little off topic.
Will get this done pretty soon and continue with testing.
Once I feel it is 100% solid and I have an answer to what will need to be tuned by the end user and how I can support it properly I will update everyone.
Whipple, a couple of questions if i can steal some of your time.
Does this little system 'talk' to canbussystem?
Well,, that´s the only question actually.
But i´m qurious about this, if it will seamlessly function in an C55 AMG.
Rgds
Patrick
Yes it does. Well I should say withing a certain range it does. Pretty much any me2.8 generation car it works with so far. I have had it in about 5 different cars now. Ranging from w203 with the m271 to an s500 with m113. I have a cl65 at the shop today that I am going to try it out on.
this is really interesting as i at this point touches the torquelimit in my tuned tcu.
Does it report to infodisplay the actual gear?
And does the shiftbuttons on steeringwheel still work?
Tip works from the shifter and most paddles just go through the shifter. If not and they are wired separately that can also be accommodated. But if it is a separate can message stream then no. These are the kind of things that vary from model and year. I will have to check them out as time goes on.
As far as tq limiters. This will have programmable limits in the tcu. Right now there are none. The reason we want peak tq limits still available is that there are cars that make enough torque to snap the input shaft off. This is really just a problem that I have seen on the Mopars that make a lot more tq. Around 900-1000lb/ft to the wheels or more.
We can run the pressures to what ever the valve body is capable of and also this is with no tq reduction on shifts, so full power.
They did change how it works in the later years but I still think it releases.
