Head Studs Required?
Old Aug 5, 2015 | 01:34 PM
jmb614's Avatar
E55 AMG
Are upgraded head studs necessary to run the mile event without lifting the heads? A mile event is coming up in Sept here and I would like to go, but don't want to shoot the heads out of the hood.
Are these necessary? Anything else that may be needed to safely run the event?
Thanks for any input!
Old Aug 5, 2015 | 01:37 PM
Forrest Gump 9's Avatar
shrimp boat
Have you looked into the rule book? You'll need at least a cage before they let you run. It's not like Texas. Don't waste your time.
Old Aug 5, 2015 | 02:35 PM
jmb614's Avatar
E55 AMG
Silly rules, thanks for raining on my parade, David.
So yeah, I guess I'll have to go to the Texas Mile. Question still stands
Old Aug 5, 2015 | 06:08 PM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
I'll be interested to hear what our experts have to say about this...
Old Aug 5, 2015 | 07:34 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
The answer depends on how much boost and timing you plan to run.
Old Aug 5, 2015 | 07:39 PM
SICAMG's Avatar
2005 e55 AMG
Cylinder pressures will not "increase" just because you stay into the throttle for a long time. At say 6000 rpm the pressures will be the same at 30 seconds or 30 min. What will happen is heat will begin to " accumulate" so to speak and if you can not keep it in check it will continue to increase and that's not good.
Old Aug 6, 2015 | 08:10 AM
nafania's Avatar
e55 amg kompressor
Lets assume around 16 psi. And upto the end of 4th gear.
Thank You Sir.
Old Aug 6, 2015 | 08:37 AM
Notdke9fdkfjekrjrkj123's Avatar
Im running 17psi without any problem with my heads!
Old Aug 6, 2015 | 09:14 AM
SICAMG's Avatar
2005 e55 AMG
The good thing is you will have a massive amount of air going through the radiator and intercooler and that will help a lot. I would also box in the intercooler behind the grill. Real easy to do and will make a huge difference in the coolers ability to cool your intake charge. The air will have no choice but to go through the intercooler and be much more efficient. I have done this on every supercharged car and its never proved me wrong.
Old Aug 6, 2015 | 09:23 AM
do you have any Pictures of that setup,did you make a box around the HE open in the front and rear?
Old Aug 6, 2015 | 09:37 AM
jmb614's Avatar
E55 AMG
I have an Aquamist HFS-3 installed as well, which really seems to keep IAT's in check. Along with a trunk tank and upgraded HE I imagine that should be enough? What should EGT's be? At the bottom of 4th to about 5250RPM I am seeing in the neighborhood of 1150-1200F. I assume that is a safe temperature?
At the bottom of 4th I see around 14.5psi with a 185 pulley, MBH Headers and 82mm TB. Im not sure what timing will be.....
Would love to see pics of your modification to box in the HE if you have them.
Old Aug 6, 2015 | 10:09 AM
Sounds like youre on the right track. I personally would consider a meth kit mandatory for any modified car with a PD blower such as these, especially planning to run a mile event.
Play around with the ratios and see what works best for your setup in regards to EGT and RWHP. I personally run 85%-100% meth depending on how hot/humid it is out. Others like more water but that's what works best for me. If the time and budget allows for it get a standalone knock sensor/monitor. That combined with your EGT gauge will be a huge asset in keeping your engine safe.
I wouldn't worry about head studs at the power level the stock blower is going to support except for if you needed new fasteners anyway.
Thank You Sir.
Old Aug 6, 2015 | 11:02 AM
jmb614's Avatar
E55 AMG
Thanks for your input, it is appreciated!
Old Aug 7, 2015 | 02:04 AM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
yeah, experts. like keyboard soldiers or people that have run the mile?
Old Aug 7, 2015 | 02:28 AM
EREBUS's Avatar
I was running @ 17 psi with every cooling mod known and my heads lifted last October. My IAT's at the end of the mile were @93 degrees and I had a custom tune (for the mile) that was set a little rich on MS109 for safety.
(I'm currently removing my heads and sending them to Shardul for a once over for the this October Texas Mile race. ARP studs are being installed)
The mile race is a different beast all together. For example:
1) Drag slicks don't work due to speed rating requirements.
2) Head winds become a problem
3) Slow staging warms up your IATs before your run.
Registration for the upcoming Texas Mile is August 9th @6:00pm. It sells out in 2 hours. I would love to see someone else from this forum run it. Not many Mercedes show up.
Old Aug 7, 2015 | 06:18 AM
jmb614's Avatar
E55 AMG
Thank you for sharing your experience.
Old Aug 9, 2015 | 12:13 AM
Max.H's Avatar
E55
Why would you lift the heads on an AMG that was designed for autobahn speeds? I think you will be fine.
Edit, I see you are modded. But, I still have not heard of these heads lifting off the cars.
Old Aug 9, 2015 | 09:33 PM
RedBullJnky's Avatar
you to Hate
2hours my a$$!!! It sold out in 1minute. I was waiting and as soon as it open and I hit register it already had 67 registered. Then by the time I hit submit, it was sold out.
I tried!!!
Old Aug 10, 2015 | 12:27 AM
EREBUS's Avatar
I tried!!!
Brother, waiting list is open! You would represent M113K very well in the mile race! Add your name to the list!
Old Aug 10, 2015 | 12:28 AM
EREBUS's Avatar
lolz. carry on, then.
Old Aug 10, 2015 | 02:43 AM
Max.H's Avatar
E55
LoLz Ok, anything you say over kill.
Old Aug 10, 2015 | 11:39 AM
you to Hate
Will do
I'm also gonna do the half mile race in GA next month with chawkins
