Able to raise / lower car after Star lowering is done?
1 Post
'03 E55 AMG - '06 300C SRT8 - '93 240SX Coupe w/1JZ-GTE
Is it possible to still use the interior raising and lowering buttons inside the car after it has been lowered via Star system or is the Star lowering something permanent? If the raise button is pressed after lowering with Star and it has raised will it return to the lowered height that Star has been set with Star?
you can still raise and lower the car but I noticed, it wasn't as much as before when stock. That's why I am going back to stock, I will ask if they can put it just a tad lower then stock.
1 Post
Right so I figure if you lower the car 1inch then the raise car function will raise the car still but it will be 1 inch lower than it used to raise to am I correct?
yes that is correct. That is why I am going back to stock maybe half inch if at all. been saying this to myself for awhile. Just need to find the time.
