E55 with 3.06
Old Aug 19, 2015 | 06:08 AM
99lightning's Avatar
99 ford lightning
I have 3.06 gears and whats nice is that in 5th it will just pull you do not have to kick it down a gear to make the car move.
Old Aug 19, 2015 | 07:11 AM
demetaktak's Avatar
04 E55 w211
How is it after 160 mph
Old Aug 19, 2015 | 08:51 AM
Amg55boi's Avatar
Cls55
Just asking here, but I understand the dodge/Chrysler 300, challenger SRT center section is the same, any truth to that?
Old Aug 19, 2015 | 08:58 AM
kponti's Avatar
E63
Well most of the chassis is the same as the dodge/chrysler 300 so it wont be a big shock if the diff is also the same
Old Aug 19, 2015 | 09:04 AM
Hulk's Avatar
A Merc
Yup, that's why I posted that you can find gears on the dodge forums, they upgrade to bigger gears a lot
Old Aug 19, 2015 | 09:42 AM
MTV10's Avatar
E55 AMG & C63 AMG
What are you guys revving at around 60mph with the 3.06?
Old Aug 19, 2015 | 11:01 PM
  #32
Amg55boi's Avatar
Cls55
What is the possibly of just swapping the center section out,
from a 300 or challenger SRT?
Old Aug 20, 2015 | 06:09 AM
  #33
99 ford lightning
I know at 160 I still have a bit left on the tach
Old Aug 20, 2015 | 12:49 PM
  #34
Max.H's Avatar
E55
What RPM are you crossing the 1/4 trap with the 3.06 final drive? It's shifting to 4th I presume?
I think even shorter would be better if you were only interested in say 0-140 mph. But, you would need LSD and drag radials for sure. Because you would probably spin a lot because of the torque multiplication of the shorter final drive.
Ideally, You want to cross the traps at the highest rpm possible just after where your peak hp is made.
