Might be front wheel bearing but not sure
Old Aug 26, 2015 | 08:04 PM
KrazyKorean's Avatar
2003 E55 AMG
So a few days ago I was driving on the freeway and noticed it was a little rougher in the front, like I felt a very slight vibration. And I ever so slightly here a hum basically like a wheel bearing going out.
Yes I know it might be that but wanted to hear other suggestions when I get to check it this weekend so I can go over everything.
But I don't notice it on lower speeds driving in the local streets.
I will check for play when I jack it up, but general how much extra play will I notice and would repacking bearings be fine or should I just change/upgrade the bearings?
Or if there is something else that can cause this.
Thanks guys
Old Aug 26, 2015 | 08:14 PM
Max.H's Avatar
E55
Check your wheels and tires first. You might have a bent wheel or some issue with the tire.
