What am I doing wrong on resetting my sunroof...?
Old 09-08-2015, 09:41 PM
cabowabodude's Avatar
E55 AMG, Silverado, Cadillac, GL450
Ok I've used the search button but every different thing I try is not working. Maybe I'm just overthinking this sunroof issue!
The issue I have is my express open (sunroof slides all the way back) works great. But when I try to use the express close the roof only goes to ~ 50% close and stays there. If I hold the express close past the 50% mark (say 80 or 90%) and let go the roof will go back to the 50% mark.
I have tried:
1) Tilting it open, and when fully open wait 5 seconds.
2) Then Pulling down (Tilt close) and holding for 5 seconds.
3) Then express sliding it back (open), and when fully open, hold for 5 seconds.
4) Then express close forward, and when closed hold for 5 seconds.
What in the hell am I doing wrong? All the windows will close if I use the Recirc button during driving but the roof (if slid fully open) will make an attempt to close but then open back up. So I'm assuming it's not fully sync'd
Thanks,
Mark
Old 09-08-2015, 09:52 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Easiest way to sync the windows/roof is to stand outside the car, point the key at the drivers handle and hold unlock down until all of the windows/sunroof fully opens, then hold lock until everything is fully closed.
Also, lube the sunroof tracks with a suitable grease. Mb makes a special grease for sunroofs and pano roofs.
Old 09-08-2015, 10:19 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Did you google resetting pano roof. When I did the it it was In an order where the roof didn't move in the process
Old 09-09-2015, 12:32 AM
Rocman8's Avatar
E55
+1
This is most likely your problem. If the sunroof motor detects excessive resistance it will reverse.
Old 09-09-2015, 10:00 AM
2000UZJ's Avatar
E55
Originally Posted by Rocman8
+1
I have this issue with my non-pano. Express will not work, I have to hold the button manually. I need to grease it before the gears eat themselves. It's pretty slow and sounds bad
Quick Reply: What am I doing wrong on resetting my sunroof...?
