W211 05 e55 amg stalls /jerks
2005 e55 amg, 2005 audi s4, 2000 audi a4 1.8T (big turbo)
Sounds just like what happened to my E55. Did the problem start after it not being driven for a while? Or after having the Batt discharged due to whatever reason? My E55 was jerking and just dying after being run for some time. Sometimes when I put my foot flat on the pedal it would start jerking too…… Crazy thing was I took it to the local Euro specialist for a Diagnostic check, all sorts of electrical codes came up. I replaced the main battery even though it was giving good enough readings and that fixed the problem flat! Some electrical gremlin manifesting its way through the battery. I’ve done over 10k in it since then with no further issues.
Update
S--t did it again.. lol i was hearing the sweet whine of the sc then i floor it and the **** stalled back and forward shaking amd again tone on the exhaust changed again and i keep smelling fuel outside tho.
Update
Ok so after getting the same shakiness and stalling when i punch it again .. i notice the car backfires momentarily before the jerking occurrences and when i down shift, im now positive its fuel related or air fuel ratio are jacked up im going to tare it down Friday and find whats causing it
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
use a fuel pressure gauge to determine the fuel pressure. It will drop real low when the stalling happens. then go tap the top of the pump assembly a couple of time and the problem should not be present for a next couple of miles.
Interesting, my main concern here is when i turn key one sep before i can crank it i smell fuel by my TB, when i turn on the car u can clearly feel the car shaking on idle like continues small misfires is running rough even when warm plus at random times when im crusing i get this light smell of fuel coming from outside followed by a smell of unburn fuel, at this point i gotta tare it down and really get in there and look.
#32
There is the possibility of a cat that is clogging up when it gets hot. This will give you fumes in the engine bay, backfire, jerking at wot...
And I'm curious what you mean by "tear down" and what you will be looking for.
#33
Oh yea totally forgot about that, and tear it down as in ,put new intake gaskets, replace injectors, fuel filter,check all vacuum leaks, knock sensors everything under the charger basically just tare it all apart.
#34
Update /possibly fix for good.
Finally results,change the upper intake gaskets.
Checked all injectors some had the o rings worn out and torn so i change that.
And finally the main reason the dam car jerks little annoying baster sensor is broken the clamps are broken so it floats there nothing to hold on to so the pressure kept pushing it out and today my car pop it out car ran like azz already order it.. finally.
Rear strut was order so ill be changing that to, my sc aux pump had a 7amp fuse so i took it out and put a 15amp dumb previous owners.
#35
What sensor is that? It almost looks like a mass air flow sensor.
#39
2005 E55, 2009 VW GLI
If you're going through and replacing 16 o-rings, you may as well replace the damper as suggested above. The purge valve may be next on your list if you still smell fuel under the hood once your work is complete.
#40
Good thing u mention that the smell is inside the car now like light not strong but u can tell specially if all windows are closed time to see the pump lol
#42
Ill wait till i fix everything on it and go from there thats all i can think of for now.
#47
Update
The IAT was change and the car idles smooth no shaking or stalling anymore hope its permanent fix , the strut dint fit they send me a e500 w211 strut air matic but its different so gotta return and reorder.
#49
That's it. ATK here is a vid of a stock E55 most on street tires will spin to 70 mph.
2004 Mercedes Benz E55 AMG 0-160MPH-0 Run in 1 mile on a CLOSED ROAD World Record? - YouTube
#50
Much wow
Well found my fuel smell , plug melted and made a hole on the housing small little hole patch it problem solved, fixed the barbecue plug as well it should run better now.
Melted housing from plug.
I patched the little hole now i blow on the plug housing and no more air escapes or vapors.
