E63 Bumper install questions on E55
Old Sep 22, 2015 | 10:43 AM
realien's Avatar
2016 AMG GTS
Hi Guys,
finally got my bumper painted and installing an E63 bumper on an '05 E55
1) Attempting to install the E55 bumper internals (the foam/support) into the E63 bumper shell, but none of it fits, so I could install just the E63 bumper without that, but it would be pretty “soft” to the touch.
2) There is no provision for the turn signals on the side, do you generally just drop those ?
3) The headlight washers are blocked by the new bumper once the pop out about 1/2 inch, they hit the new bumper, have others just not used them ?
Old Sep 22, 2015 | 11:20 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Buy the E63 bumper internals
Old Sep 22, 2015 | 12:49 PM
realien's Avatar
2016 AMG GTS
Hmm, I bought the bumper for Gary Suvineer, and I would have assumed the internals came with the bumper, I'm checking with him if thats some additional parts I need to purchase.
With the E63 internals, is it bolt on to and E55 ?
Cheers
Grant
Old Sep 22, 2015 | 04:12 PM
HeissRod's Avatar
No, Gary does not supply the internals. Some people opt to run without them instead of buying them.
Here is a link to the front end conversion thread, with the listing of recommended parts:
https://mbworld.org/forums/w211-amg/...ml#post5310580
I'm getting ready to order all of these parts in the next week or so.
Old Sep 22, 2015 | 08:20 PM
realien's Avatar
2016 AMG GTS
yeah, Gary told me what to order, I brain farted
Looks like I'll need
2118850516 Bumper reinforcement left - $16
2118850616 Bumper reinforcement right - $16
211-887-03-27 Pull For Hood Latch $4.25 (This replaces pull on E55 hood latch, you do NOT need the entire E63 latch)
211-880-07-03 Center Inner Plastic Support $20.15
211-880-09-03 Inner Plastic Support $32.50
211-880-10-03 Inner Plastic Support $32.50
and can re-use the foam from the e55 with some trimming.
Gary didn't list the first two parts but the main thread mentions them, are they needed ?
Old Sep 22, 2015 | 09:01 PM
HeissRod's Avatar
Where are you getting your prices? My supplier is cheaper on some and not on others. This is what I put together:
Hood Latch Pull 211-887-03-27 $5.06
Inner Plastic Support 211-880-09-03 $39.00
Inner Plastic Support 211-880-10-03 $39.00
Inner Plastic Support - Center 211-880-07-03 $23.25
Lower Bumper Reinforcement - Center 211-885-03-16 $27.75
Lower Bumper Reinforcement 211-885-05-16 $12.00
Lower Bumper Reinforcement 211-885-06-16 $12.00
Lower Bumper Reinforcement 211-885-07-16 $25.13
Lower Bumper Reinforcement 211-885-08-16 $25.13
Impact Absorber - Center 211-885-13-37 $36.38
Impact Absorber - Left 211-885-15-37 $34.50
Impact Absorber - Right 211-885-16-37 $34.50
Old Sep 22, 2015 | 09:20 PM
JoeNobody's Avatar
Mercedes
My headlight washer flaps don't line up very well, and in hindsight I should have bondo'd over them as I plan to relocate the headlight washers so they spray on the front head exchanger.
If you have parking sensors then search for some of the more recent threads, and it'll give guidance for how to install (use heavy duty sealant on the SLK parking brackets).
Old Sep 22, 2015 | 10:45 PM
black06c230's Avatar
mgLipGD
Just move the 55 brackets over to the 63 bumper. That's what I did.
Old Sep 23, 2015 | 12:45 AM
realien's Avatar
2016 AMG GTS
I think those were retail prices, I generally buy parts from
http://www.mbpartsworld.com/
thanks for the list!
Old Sep 23, 2015 | 10:58 AM
e500slr's Avatar
2011 E63, 2013 CLS63
DON'T BUY ALL THAT'S ON THE LIST, you DO NOT need all of them....
You need...
....and the foam if you really want some padding but it will be fine without TRUST ME, that other stuff has nowhere to go.
The left and right brackets, between the fender and bumper on the sides are the same. The hood latch you could also get away with but it will be a little annoying opening it with the short one.
Old Sep 23, 2015 | 08:16 PM
JoeNobody's Avatar
Mercedes
$5 for a hood latch that works as designed? I'd pay that.
Old Sep 23, 2015 | 11:43 PM
e500slr's Avatar
True, you're right but where I am it's ALOT more and I just couldn't be bothered. I'll do it sometime but I've gotten used to the short one I'm so cheap hahaha
Old Oct 3, 2015 | 11:45 AM
realien's Avatar
2016 AMG GTS
Ended up using new plastic mounts
