My car wont shut off after taking key out, wtf?!
Old Oct 5, 2015 | 08:44 PM
nepats's Avatar
Camry
this happened once before but thats when i used the push start. Like how is this even possible? what should i do right now?
Old Oct 5, 2015 | 09:41 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Does it if you hit the stop bottom on gearshift?
Old Oct 6, 2015 | 12:39 AM
nepats's Avatar
Camry
nah, i got it to shut off after driving around my neighborhood for a little while though. weird.
Old Oct 6, 2015 | 07:32 AM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
So are you using keyless go or the key? You say taking key out then say using push start? I don't understand what you're doing. If you use keyless go "push start" you keep the keys in your pocket, put your foot on the brake and push the start button. If you're using your key, you put it in the ignition and turn it like a regular key. If you're using keyless go, start the car and just walk away with it running it won't shut itself off either.
Old Oct 6, 2015 | 08:01 AM
nepats's Avatar
Camry
I was using the key. The engine wouldn't turn off after removing the key.
Old Oct 6, 2015 | 10:43 AM
mAMG's Avatar
SL55 2003
Originally Posted by nepats
I was using the key this time. The engine wouldn't turn off after removing the key. It happened another time with the push start and when I brought it to MB dealer they said they couldn't find anything and it happens sometimes with the push start
Disconnect the battery for 30min.
