If I'm going to replace lower ball joints what else should I do when I'm in there...?
Going to tackle the lower ball joints in a few days. I have the ball joint separator and a ball joint press for the W211. I'm not typically one for replacing parts just to replace them! But....does it make sense to replace the upper ball joints as well? I hear a lot about the lower ball joints going bad but I'm not sure about the upper. How hard is it to change the upper at a later date?
I just put on new brakes/rotors within the last 1K miles. Looking for input.
Thanks,
Mark
Thanks,
Mark
Upper balljoints can be done by themselves in about 20 minutes per side. The only special tool you need is a tie-rod end separator. Not because you're taking apart the tie rod ends, but because it fits our small balljoints better than the wider balljoint separator. I borrowed one from AutoZone.
Last edited by JoeJErnst; 10-05-2015 at 01:11 PM. Reason: clarified what I meant by "uppers" (balljoints, not control arms)
2005 E55, 2009 VW GLI
Thanks,
Mark
Thanks,
Mark
I recently replace my control arms and tie rods. If I had to do it all over again, I would have left the upper control arms alone and replaced the ball joints on them only. The bushings on the upper control arms still looked good after 105k miles.
Pull on your sway bar to see if it slides in and out of the sway bar bushing. If so, plan on replacing it as well.
I still have my lower control arms. You, or anyone else, can have them if you're up for pressing in new bushings and intermediate ball joints. Just pay shipping.
-OA
'05 E55, ‘00 ML55, ‘92 500E
I just did upper and lower ball joints over the weekend and I still hear a faint popping noise inside on the drivers side when I go over a bump.. Any idea what that may be?
Report back after you fix it and tell us what it was if you could.
2014 CLS 63 S AMG / 2004 E55 AMG
I'm facing the same issue. But my front end is starting to feel sloppy, and my E55 has 153k on it. I decided to go with new upper cont. arms (w/ ball joints), lower ball joints, lower cont. arms, lower strut arms, and new wheel bearings (all Lemforder / febi). I got everything for around $900 shopping it around different sites.
I should have everything together by the end of next week...
im about to do the same and replace all the upper and lower ball joints, tie rods, etc. need to check sway bar bushings, sucks you have to replace entire sway bar as they dont just sell the bushings. Doing upd rear camber arms as well.
should be fun winter project, car better drive like new !!!!
One of my lower ball joints was shot so I decided to replace:
Have not had the chance to drive the car yet as this was just one of the side projects while my motor was being rebuilt. But after 7 months the motor is being dropped in as we speak and I'm finally going to be back behind the wheel in a couple of weeks (assuming no unforeseen issues.)
- Upper Ball Joints
- Lower Ball Joints
- Upper Control Arms
- Lower Control Arms
- Tie Rods
Have not had the chance to drive the car yet as this was just one of the side projects while my motor was being rebuilt. But after 7 months the motor is being dropped in as we speak and I'm finally going to be back behind the wheel in a couple of weeks (assuming no unforeseen issues.)![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
- Upper Ball Joints
- Lower Ball Joints
- Tie Rods
