Solid pulley install questions
I have a solid pulley that I purchased and I received it with two resistors and some vague directions. I am unsure wither they will go in line and reconnect the plug into the snout or leave it unpluged. Or baybe it gets looped from one wire to the next. Any help would be appreciated and pics would be great.
Thanks in advance
Thanks in advance
PLATINUM SPONSOR
Thanks in advance
Thanks in advance
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
