Can I do this retrofit?
2015 Jeep Grand Cherokee, 2005 E55
I have 05 w211 with Dynamic headlights. Want to do Depo E63 style with EvoXRprojectors.
I've read 100 threads on this but can’t find solid info pertaining to mycurrent set up. I know you can do it on non-dynamic setups.
What is the easiest way to go this? I can swap the guts & lens of thedepo into my stock housing if need be.
Get Depo lights - use the cover and inside
Get new lenses - swap active proj lens
I used these
http://www.theretrofitsource.com/com...l#.Vig0poo8KJI
Or these but double check they are compatible
http://www.theretrofitsource.com/com...l#.Vig004o8KJI
D2S Bulbs - not the "new style color" but the Osram CBI are true 5000k and among the best you can get but about $160
http://www.theretrofitsource.com/com...l#.Vig0L4o8KJI
Bulb and lenses you can get from theretrofitsource.com
I used these
I have the E63 facelift buckets they are brand new. they have my old plastic covers on them that need to be polished. I want them our of my garage and will make a deal. The box is large so if you're socal local you can save a bunch on shipping
I could be wrong but I remember people posting about dynamic compatible DEPO lights but they do not come with the ballast or modules so you just reuse your own.
