2006 e55 Brake Pads, Rotors, & Sensors
So I replaced my brake pads this morning and wanted to share a few interesting tid bits since I found lacking or mis-information elsewhere...My car is a 2006 e55.
Front rotors measure 36 mm (new) and the minimum thickness is 34 mm.
Rear rotors measure 26 mm (new) and the minimum thickness is 24 mm.
According to MB, my car should have had 3 wear sensor (2 up front & 1 rear), yet mine only had 2 (1 up front & 1 rear) on the passenger side.
Up front there are 8 pads (4 for each rotor) and there are 4 pads in the rear (2 for each rotor).
