S/C Belt size for 77mm?
CerBErusM113 (08-21-2016)
I know a couple using the stock belt with a 77mm, it works but.......both are quickly ordering belt wrap kits, also I am using a 77mm with a belt wrap kit using the belt that comes with it for the stock SC pulley and it is a little loose, i get the odd squeal when powering off at high RPMs like I did before the BWK which eliminated that squeal on a stock pulley, next time I replace the belt I will find one 5-15mm shorter which will help
