Supercharger Serviced
Old Nov 6, 2015 | 01:50 PM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
Before the supercharger was bolted back on my rebuilt motor I wanted to make sure it was in good condition with nothing lurking inside so took it to a supercharger specialist. Just as well since they found a couple of small pieces of hose caught inside the rotors and several chewed up fragments of rubber in the intercooler which (thankfully) in this instance served as a secondary filtration. A small section of teflon had torn off a rotor as a result and needed to be cut back and smoothed as teflon cannot be recoated. Also as expected both rear bearings had completely dried out and required re-greasing.
Old Nov 6, 2015 | 01:53 PM
Hotsauce55's Avatar
2005 E55
How do you re-grease those bearings?
Old Nov 6, 2015 | 02:00 PM
Here's the direct link to the post with instructions plus lots of other interesting info on the supercharger:
https://mbworld.org/forums/w211-amg/...ml#post6517492
Old Nov 6, 2015 | 04:11 PM
99lightning's Avatar
99 ford lightning
that damn plenum where the tb goes is robbing us power
Old Nov 6, 2015 | 05:10 PM
Zed82's Avatar
E500 -03
How many miles do you have on your beast? Heavy tuned?
Trying to figure out whether my SC needs regreased bearings. I have 80 000 on the clock. ECU tune last 15000 miles, before that stock.
Old Nov 6, 2015 | 05:26 PM
sexyxe's Avatar
04 E55
Lucky find. I'd imagine a severe look of disappointment to put it all back together only to have smaller on going issues in the future.
Old Nov 6, 2015 | 09:17 PM
£ C43 £ AMG £'s Avatar
E55K AMG
brake cleaner and high speed bearing grease
charger looks like it sucked in part of the breather intake pipe located under the TB
Attached Thumbnails Supercharger Serviced-dsc_0170.jpg   Supercharger Serviced-dsc_0249.jpg
Old Nov 6, 2015 | 09:26 PM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I just pieced together a new S/C for my car. I used the grease out of 2 new top of the line Makita skill saws for the end bearings. It's the only thing I could think of that spins that fast and is made to last for years. Kind of expensive grease, but hey, it was there and I trust it to work.
Old Nov 6, 2015 | 10:15 PM
Yep don't we know it...
There's 120,000 miles on the clock but everything major has been replaced. Currently just running a canned Eurocharged tune.
I would definitely be regreasing your rear bearings. It's preventative maintenance that most people neglect. There is a 99% chance your bearings have completely dried out and it is just a matter of time before your supercharger will need replacing as those rear bearings are (apparently) not replaceable - although Australian member NSWEurocharged has sourced some new bearings which should be available in February/March. It has yet to be determined if they can be replaced without issues yet though...
I "almost" didn't have the supercharger opened and serviced but thought the exact same thing. No point in spending all that time and effort (and money) only to deal with problems that could have been avoided.
Anyone looking to do it theirself make sure you thoroughly clean the old grease with the brake cleaner (or whatever you use) as the new grease can react with remnants of any old grease left behind.
Yep, that would be the culprit!
That sounds like the go. I wish I'd asked what type of grease they used? The guys I took it to build their own range of superchargers in addition to being the authorised repair agent for other brands, so know what they're doing. I might get in touch with them anyway and see if they don't mind sharing what grease it was.
Old Nov 10, 2017 | 08:47 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
That little rubber piece looks like the nipple that goes into the throttle body from the PCV hose.
Old Sep 10, 2020 | 01:34 PM
Hamadi's Avatar
MB CLS 55 AMG
Hello Guys
I´m trying to refresh my SC with new bearing
but I couldnt found the part number for the metal gasket in the middle section of the SC,
between the first part that has the pulley and the other part where the turbines are,
can anyone refer me to the right part nymber to those two gasket.
Sorry dude if i did use your pic
