Just installed SC pulley and belt. Have questions
Old Nov 11, 2015 | 07:11 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Car started up sounds fine. I noticed the magnet clutch on the sc was turning. If I push the palm of my hand against it, it will stop. It takes some resistance to stop it. Gap is .38-.59 depending where you check. It rotates freely when it's not started.
Can someone go do a cold start and see if yours is engaged at first?
Thanks tony
Old Nov 11, 2015 | 07:55 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
This is normal.
Old Nov 11, 2015 | 08:44 PM
Ls1toAMG's Avatar
Ok thanks. I let it warm up to running temp or real close 80c and the resistance was much less
