e63 rear tire configuration: 295/30/20 on 20x10.5 +42 ...will it rub?
I found a local guy with the proper tools who did mine for $15 per fender.
27.2" tall versus the stock height of 25.3". Big difference.
Here is a good calculator to use.
https://tiresize.com/calculator/
Are the inner quarters rolled up at all from the factory?
My background is collision repair and I've never seen any rolled up like the ones on my car....but I've never worked on a MB.
I thought about using the 305/25/20 but wasn't sure they would clear since the 295 was so close.
My wheels are the VSF1 Vossens. the wheels were on the car when I bought it and think the rears are 10.5. At least that's what I've found here.
http://www.getyourwheels.com/view-wh...ll/vehicle-all
So I guess my question is what did you have to do to make the 305s fit?
Also just how close it the tire to the edge of the quarter and to the splash shield on the inside?
And how close to the shock.
I need to replace my tires but want as much info as possible just like you do.
Plus a wider tire is always badass.
I want to see your car also. I see part of it in the sig line.
Nice, thanks for letting me know. Do you have any pics?
Can you describe a "basic" fender roll or close up pics.
I'm sure mine is done but since I'm new to the E55s.
Is there a topic on rolling the quarters?
I like my 295/25s and want to go to the 305s is possible.
My "roller" used the Eastwood device that mounts to the wheel hub.
They need to gently heat the fender "lip" area (makes the paint malleable) then roll with evenly applied pressure.
If you feel with your finger in the inner rear fender and there is an "edge" you'll need a roll.
I didn't take pics of the process but that's how mine was done.
So now if you roll/ flatten that edge even more what happens with the liners in the lip? Can they still be removed?
CarbonHan did you get those tires put on?
Let's see them!
Let's see them!
I've been told that the tires will arrive tmrw in the AM. I'll post up pictures once theyre put on.
305/25/20 will work for sure but I'll never go under a 30 series tire again, you give up way to much ride quality below 30 it's horrible.
305/30/20
305/30/20
295/30/20
295/30/20
305/30/20
305/30/20
295/30/20
295/30/20
My m5 is on coilovers (8k/6k sr)though so I may be used to the abuse haha
