BC coilovers- which model do i need?
Hey guys,
Im convering my w211 e55 from airmatic to BC coilovers and want to make sure which model do i need:
J-06
http://www.redline360.com/bc-racing-coilovers-mercedes-e320-e350-e500-J-06
J-05
http://www.frsport.com/BC-Racing-Suspension-J-05-BR-RS-BR-Type-RS-Coilovers-Benz-E55-AMG-W211-03-06_p_398840.html
which one is the one suitable for the conversion in my car?
Tnx
J-06
J-05
Tnx
Hey ,
. I just talked to BC and they said that you will need a non airmatic rear lower control arm for it to work.
actually the front spring is different depending on year.... what year is your E? all the rear springs are the same according to part numbers....
i just had a set of these installed. What a difference in ride. i ppicked up the items below for the installation:
2 rear lcas 2113501806
2 spring insulators 2113250384
2 brackets 2114270541
2 lca covers (optional) 2113520388
def will need an alignment afterwards. The settings from factory lowers the car to almost the lip of 19 rims.
As someone else said. Search the forums. There are at least 3 specific threads, one is a complete step by step DIY if you want to go that way. I bought my setup straight from BC Racing, they had the set in stock. Running 24 clicks (32 total damper settings, 0 is full soft), I bought my arms on Amazon, you don't need all of the other parts. You can pull Fuse F37 and the airmatic won't be red on the dash, you will just get an instrument malfunction and you can clear with the arrow on the steering wheel.
Thank you all for your help!
Finally i purchased the J-05 and tomorrow is the installation.
I would like to know how you recommend me to tune the coilovers.
I would like to have the ride height about 1-2cm lower than the airmatic sport 2 mode.
As for the ride comfort i dont mind it will be about 10-20% stiffer than sport 2 mode, means slightly stiffer but not too jumpy or bone breaking (my 3 & 5 yo kids riding the car daily).
my car has the stock 18' wheels on it for that matter.
Thank you!!
Thank you!!
Thank you!!
Thank you!!
This is a street spring rate setup so it's not going to be bone jarring. I found that you need to go pretty far (32 clicks total - 0 total soft, 32 full stiff) into it to control the weight of the car and the rebound. I am at 24 clicks and have been running that way for about 3 months now. I could use a tad more rebound control but since it's not individually settable, the only way to get more rebound is to set more compression. Good news is that it's just knobs (rears are behind the carpet so not quite as easy so you can just drive it, change it and drive again until you get it where you want.
Thank you for your comment.
From what i understand the damping is easy to tune after the installation but the rear ride height is a PITA to adjust once installing, thats why i prefer to prepare initial setup before installing and do only final ride height adjustments once installed.
Any suggestions on that?
I really want to keep car in decent height, about 1-1.5cm lower than stock sport 2 mode.
Thanks again!
Thanks again!
