2007 e63 Suspension question
Is there a way to at least get an idea of what is up?
This started happening within a few days after Mercedes doing the fuel tank replacement TSB. Coincidence or migh they have not plugged something back in?
TIA!
TIA!
it seems that you have a air leak to the rear or at a rear strut. from what i remember the rear shocks are tied together so if one is damaged the other might be affected, but i'd double check that.
if you have a leak your compressor would run continuously to compensate, then burn out and possibly burn out the relay from what i've read. you might have to end up replacing the part that is leaking as well as compressor and relay.
That being said, I love my car. Probably still will when I'm eating ramen noodles, too.
Book time on one bag is 6.2 hours and both 6.5.
Of course, they charge $681 for the bag.
There must of been a leak for a while because the car now sits overnight without drooping in the back.
