perfect atco air today
Old Dec 20, 2015 | 03:47 PM
99lightning's Avatar
99 ford lightning
The air was perfect I actually saw 13.6lbs of boost with the stock pulley in 4th gear. That's if that conversion is right from dasdaq 27.7psi/hg that's why you run race fuel always. however the launch pad was brand new at atco we were all spinning. I only went 11.7 at 122mph. it boiled the tires causing that 1-2 shift to hang up I got a first gear slip code, cleared it with star. also again with my fabtech tank not sure whats going on but at 114mph my act is at 142 deg and I finish at 154 deg, my run started at 52deg. mind you with stock heat exchanger and 03 cobra tank when I had those items I only had a 50 deg rise in act temp when it was about 55 deg out. I would finish at 113deg act. so not sure whats going on with this setup I have now but all considering im making good power not hooking I even lost about 6 deg of timing from it being pulled. remember this is all with stock shift points. I had more fun flying on the high way driving to and from the track. its a missle with these gears it just doesn't hook.
Old Dec 20, 2015 | 05:47 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Atco is open ?
Old Dec 20, 2015 | 06:54 PM
99 ford lightning
Just for today, pretty good turn out
