went to replace ic pump with bosch 10 ran into small issue
so turns out the PO installed a johnson pump , looks to be half the size of the 010.
the A hole who did the install cut the oem plug and spliced into harness, what kind of plug does the 010 require?
problem 2, the johnsons circumference is half of the 010, any tips on where to get a appropriate bracket or DIY for a bracket?
thanks in advance!
happy holidays
thanks in advance!
happy holidays
Look up the bracket part number using EPC and buy replacement bracket and harness, or start scrounging through eBay ads for junkyard pumps and find one that has the harness and bracket (preferred choice).
