Help with CGW reprogramming
Old Dec 31, 2015 | 01:03 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
All
I recently was coding the CGW and accidentally clicked Initialize and backed out. However, the DAS is giving me the following error forcing me to go through the initialization process:
When I go through initialization, I get the following error and select offline mode:
It allows me to get to the very end including updating the CGW firmware and recode everything but then right after I cycle the key, the DAS program crashes:
Does anyone have any insight on what I can do here? If there is a setting where I can set the CGW to at least think that it has been re-initialized, that might help. I have a 2010 DAS developer version.
Thanks!
Old Dec 31, 2015 | 01:52 PM
JoeNobody's Avatar
Mercedes
Do you have Xentry app running? Certain operations in DAS require Xentry to be running in the background, otherwise you'll get obscure errors.
Old Dec 31, 2015 | 02:38 PM
turbo97se's Avatar
No I do not have Xentry running just DAS .. didn't even think about Xentry .. thanks for reminding me .. someone actually told me that a long time ago and I forgot about it (may even have been you) ... I can do pretty much everything else within DAS so didn't think of it. I'll give it a shot.
Old Dec 31, 2015 | 05:36 PM
turbo97se's Avatar
Well tried Xentry but no luck .. SW still crashing … any more thoughts from anyone?
Old Dec 31, 2015 | 06:13 PM
das eighty's Avatar
'04 E55 AMG
Make sure there is only one instance of it running in the background? (Task Manager: Processes, Services, etc)
Have you done a full reboot of the laptop? Unplug everything and retry.
I had an issue on my buddies setup a while back with Java preventing me from progressing. Needed an update.
Worst case, as tedious as it sounds, uninstall/reinstall DAS. =/
Old Dec 31, 2015 | 07:27 PM
JoeNobody's Avatar
Mercedes
Try a different and known working Xentry virtual machine image? Faster than reinstalling DAS. I'm using 2012 and it works well for me (also has hack re-enable developer menu for NTG2.5 functions).
Old Jan 3, 2016 | 08:41 PM
Mackhack's Avatar
Start up your laptop and send me your team viewer access ID and password via PM.
Old Jan 3, 2016 | 11:59 PM
turbo97se's Avatar
Thanks ... unfortunately, I am out in China on business again .. back on 18th .. I'll hit you up right after I get back .. thanks
Old Jan 4, 2016 | 12:06 AM
Mackhack's Avatar
Cool beans.
Old Jan 5, 2016 | 05:26 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
That is a software issue. Maybe your das/xentry needs to be updated. Is this your laptop?
