What are you using to clean the supercharger and engine covers?
Old Jan 4, 2016 | 12:53 AM
Doug427's Avatar
2006 E55 AMG, 2018 Audi Q7, 2005 Porsche Boxster S, 1930 Model A Hot Rod, 744HP 1965 Shelby Cobra
My car arrives today, first thing I would like to do to it is give the engine a real good cleaning. The engine is actually very clean in general, but there is some grease built up in the squares in the casting on top of the supercharger, and a small bit of discoloration in the engine cover and the pieces that say AMG (what are they, by the way) on the top of the engine. Appearance tips, products and procedures would be appreciated.
Old Jan 4, 2016 | 01:10 AM
knowbenz's Avatar
Benz
Pressure masher then gentle rinse with garden hose then cover in foaming tire shine
Old Jan 4, 2016 | 07:00 AM
2000UZJ's Avatar
E55
I used a steel brush on the supercharger to clean off the deposits and quite a bit of shop towels and de-greaser to get off anything else. I would not advise sticking a pressure washer in the engine bay, way to many air lines and electrical components in there not designed for 2000PSI water intrusion.
Be easy on the plastic bits, the air lines are brittle and don't like being moved around. Work slowly and carefully.
Old Jan 5, 2016 | 01:08 AM
knowbenz's Avatar
Benz
2000psi is not enough for tough baked on grease. I use minimum 3200psi hot pressure washer, i can crank it up to 4500 if needed, the gentle garden hose afterwards helps to sort of "flood" all the tight spots like by the injectors and the bigger debris just kind of floats on out.
Old Jan 5, 2016 | 05:22 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
wheel cleaner, non acidic, and steam clean....
Old Jan 5, 2016 | 07:14 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Originally Posted by Doug427
... and the pieces that say AMG (what are they, by the way) on the top of the engine. ...
Those are called "Surge Tanks"
Old Jan 5, 2016 | 09:29 PM
FLINTY55's Avatar
E55
Simple Green, brush and rinse.
