e55 hid aftermath problems
Old Jan 16, 2016 | 05:42 PM
mr.right's Avatar
cl500
Okay I have searched for a while and have not seem to find any threads with this exact issue I know what it is doing. Just want to understand why so I don't keep buying Sam's.
Okay so about 3 months ago I bought a 55w 8k hid kit (can-bus no CEL) about a month and a half into it the passenger side lights stop working. I mean high beam, fog lights, low beam, and turn signal. Found out the sam under the passenger foot area was fried. (I researched thanks to mbworld and found out that the sam controls those things and I saw a wire looked burnt.) So I replaced it and the lights worked flawless until tonight it shut off again I had a spare sam sitting around so I just threw it in there and It came back on, have not coded it yet so I took it back out but I want to know what could be causing the sam to be frying like this. Thank you for any help in advance.
Old Jan 16, 2016 | 06:02 PM
cptncreme's Avatar
2008 C63 AMG
55w is prob too much, should have stuck with a 35w kit
Old Jan 16, 2016 | 06:56 PM
black06c230's Avatar
mgLipGD
Yep picky car so my money on the 55w ballast too
Old Jan 16, 2016 | 07:37 PM
2000UZJ's Avatar
E55
Stock wiring can't handle prolonged 55W draw. 55W draws too much power and can overheat wiring/fuse panels.
Old Jan 16, 2016 | 08:05 PM
mr.right's Avatar
cl500
Okay makes sense I did research before I did it and I seen some guys running them I had my indy Mechanic turn xenon present on. But I will go get some 35w and see how that does. Thank you for the replies guys
Old Jan 16, 2016 | 10:06 PM
2000UZJ's Avatar
E55
Is one side working? If so swap the ballast side to side and see what happened. Problem follows its the ballast, problem stays it's the wiring.
Old Jan 16, 2016 | 10:36 PM
mr.right's Avatar
cl500
Tried that and no it does not follow. Take in mind that nothing on my passenger side works. Only light that works is the side marker but my fogs,high and low beams, running lights/city lights, and turn signals all do not work
Old Jan 17, 2016 | 05:54 AM
ss.dna02's Avatar
05 E55 AMG
I have a problem like this but with my Fogs. I have a 35w morimoto kit with can bus and my driver side wont turn on for nothing. I tried different can bus error deleters and swapping left for right and nothing. If i put back the halogen bulbs, they work.
Old Jan 17, 2016 | 01:33 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Can you use the circuitry in the car to power a simple relay, then route the high-current lights' power from the battery through the relay to the lights?
We used to do this when we installed aircraft landing lights into 1960's American cars. Their light switches had built-in circuit breakers that couldn't handle the current draw. Running a fused line through a relay solved that problem permanently.
Old Jan 17, 2016 | 01:44 PM
mr.right's Avatar
cl500
Okay so bought some 35w 8k and changed sam let's see if it last.
Old Jan 18, 2016 | 04:20 AM
bobgodd's Avatar
2004 E55
Are you running these in halogen projectors? If so your light output is going to be awful.
