Transmition oil cooler
I have a B&M cooler I am in the process of installing. Any good sized cooler will be an improvement over the risk of the OEM one busting and mixing with the coolant.
E55 amg 2004
http://www.bmracing.com/products/702...te-type-black/
This is what I am using, it will give you what you want along with eliminating the risk from the OEM design. If I remember correctly it is rated for 30,000 BTU. Do remember that the stock cooler is in the radiator so it will heat the fluid to a certain point.
