ET Predictions?
Old Jan 27, 2016 | 07:27 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
ET Predictions?
I'm doing some winter upgrades and I thought I'd get your opinions on how it will affect my ET in the 1/4 mile. I'm concerned that I may need to go rollbar shopping.
Last year I ran a best of 11.96 running Hoosiers, PLM H/X, and long tube headers.
My winter mods this year will be:
82mm TB
Methanol injection (for cooling only)
Tune by Lawshee
Still running stock boost.
Any predictions on my ET, assuming the same weather as when I ran 11.96?
Old Jan 27, 2016 | 08:15 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
What tune are you running now?
Old Jan 27, 2016 | 08:26 PM
RedBullJnky's Avatar
you to Hate
I believe there were a few members running headers and 82 tb on stock boost a few years back. Think they were between 11.4-11.6.
Old Jan 27, 2016 | 08:34 PM
JoeJErnst's Avatar
Stock Tune
Old Jan 27, 2016 | 08:38 PM
Ls1toAMG's Avatar
Somewhere in the 11.4 range like RBJ said. Tony is good. To be honest I'm not sure how much meth will help with headers and Your heat exchanger if,the weather is fair. Can't hurt
Old Jan 27, 2016 | 09:26 PM
E55Greasemonkey's Avatar
This place is a joke.
82mm picks up .1 and 1mph. You really need to up your boost with a pulley, street driving with long tubes on stock boost has to be pretty lame. I'm guessing 11.60's/70's
Old Jan 28, 2016 | 04:18 AM
99lightning's Avatar
99 ford lightning
no tb here
Old Jan 28, 2016 | 12:26 PM
SilverStrk's Avatar
05 E55, 07 ML500
I say 11.5/11.7 depending on 60ft. You Need More Boost if your going to add the TB to go with headers.. More air in more air out. If your going to run meth you can Really push the boost, otherwise I wouldn't go higher than a 185 pulley do to heat.. TB upgrade really improves throttle response. Good luck..
Old Jan 28, 2016 | 08:32 PM
Max.H's Avatar
E55
Mix 50 50 race gas MS109 and pump gas and Im thinking you can run 11.2 - 11.3. GL!
Max.H's Avatar
E55
Mix 50 50 race gas MS109 and pump gas and I'm thinking you can run 11.3 with good track conditions.
Old Jan 29, 2016 | 09:06 PM
djempirE55's Avatar
E55, Granturismo, F430, 993, E39, Jag
Get the pulley and tune - Meth injection will compliment everything. You'll be deep in the 11's with a good tire.
Old Jan 29, 2016 | 09:16 PM
Ls1toAMG's Avatar
Wile a agree with the pulley and tune crowd, some people want to run stock boost and max out power. I respect this aspect. 99lightnig and awol on stock pulley will outrun 90% of the members here. I did pulley and tune first. Some don't want to do a pulley. The fact he hasn't done it yet I would say say the op (joe) is in that crowd.
Old Jan 29, 2016 | 09:23 PM
djempirE55's Avatar
I personally don't understand the logic especially when meth is being introduced into the "mix"...pardon the pun. Meth is ideal if boosting at a higher than stock rate. To each their own.
Old Jan 29, 2016 | 09:47 PM
Ls1toAMG's Avatar
Meth is for cooling. Like a killer chiller or trunk tank. Some people like a stock pulley set up. You don't have to understand it just respect it that's all. Actually we learn a lot from these set ups.
Old Jan 29, 2016 | 11:33 PM
you to Hate
Agreed
