E63 2007 Gear Shift Problems
Old Jan 29, 2016 | 10:52 AM
2007E63-AMG's Avatar
2007 E63
My E63 has done 150,000kms. I've only had it 2 weeks and today I was stopped at the lights and it just wouldn't pull away at all, like I was in neutral. I put it in park and that then made it kick back in to life, but later on it would not come down out of 7th gear, and also the M/C/S button didn't work. That then worked after I had turned the car off and back on again. Also one time it wouldn't find second gear, even though I had pushed it up to around 4000 rpms in 1st. In summary it seems pretty fuc*** to me and no doubt expensive.
Any thoughts folks ???
Old Jan 29, 2016 | 11:18 AM
Rocman8's Avatar
E55
Search 722.9 conductor plate. The speed sensors fail.
Old Jan 29, 2016 | 11:36 AM
Shadow5501's Avatar
Car free at the moment
Conductor plate or valve body. Have the codes read by an MB dealer or MB specialist independent. Budget $2K to repair. You may get away with less, unless codes indicate the transmission is slipping.
Old Jan 30, 2016 | 01:16 AM
2007 E63
Update
So I had an independent garage run a diagnostic test and defect 0717 and 0718 came up which are "Component Y3/8n1 turbine speed sensor VGS is defective" and "the signal from component Y3/8n1 turbine speed sensor VGS is not available".
I have been advised that it will cost between $3 and 5k to repair using a specialist independent (specialists in transmissions) and a whole lot more if I go to Mercedes....
Any advice folks ?
Old Jan 30, 2016 | 01:20 AM
Rocman8's Avatar
E55
Any advice folks ?
You've been lied to. You're looking at 1500-2000 at a dealer.
