Sun visor hinges
Old Jan 30, 2016 | 09:37 PM
thtguy's Avatar
2017 GLS 550
Sun visor opened up to look at hinges
So passenger visor was separating at one corner so I decided to open it up to get a better look at this hinge issue. Not sure how many of you have thought about potentially destroying a $300 visor.
Going to figure out best type of lubricant. Something that is Styrofoam friendly. Recommend not using WD40 as it will dissolve the foam.
Here are some pics
2 o-rings on end
Black piece is metal
Rod sits in a plastic channel
Old Feb 2, 2016 | 03:03 PM
thtguy's Avatar
2017 GLS 550
ok so pulled the 2 o-rings off the slider and the bar slides right out. pulled the entire plastic frame out and used a large bottle brush and some dawn and water to really clean the inside of the slider and rinsed it well.
Afterward sprayed it down with silicon spray (liquid wrench with PTFE additive) pushed and pulled the bar through it a bunch and wiped off all the excess lubricant and rotated it a bunch to make sure the lubricant got down in there really good. wiped it down really well and let it sit for 24+ hours. made sure nothing was dripping and put everything back together.
Using some Elmers epoxy that I had that said it was good for everything including fabric. let that sit for 24hrs with clamps on it. Works like new!
Hesitant to pull apart the drivers side since it isn't delaminating any. Might just try to shoot some silicone into the hinge and just work it a bunch and see how it does. Wish I could find some in a dripper bottle. Might need to spray some into a bottle and drip it myself.
Old Feb 2, 2016 | 07:14 PM
actech's Avatar
2006 E55
great info thanks
Old Feb 2, 2016 | 08:11 PM
Bean93x's Avatar
'05 E55, ‘00 ML55, ‘92 500E
Don't have a separating issue with mine but I have noticed that the driver visor doesn't sit flush and tight to the roof as the passenger anymore, it sort of hangs about a half inch. Maybe I need new clamps?
Old Feb 3, 2016 | 08:32 AM
thtguy's Avatar
2017 GLS 550
No it is because the hinge is stiff and not rotating to the flat lock. The hinge is essentially a steel tube with a flat side. and a steel spring clip holding it in place. Pull the visor off the car. slide the bar as far out as it will go. clean the bar, I would use acetone then slid the bar in and out till it feels a little looser, wiping down with the solvant each time. then spray bar with a lubricant (i used liquid wrench silicone spray) spray a little on the hinge you can see inside the visor. then just work it around a lot spinning the bar in the visor. it should loosen up. I am about to do my driver side that way since it isn't separating. The passenger side works good as new and sits flush to the headliner.
Old Feb 3, 2016 | 10:08 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Excellent pics so far. Post more when you do this process to your other visor.
Old Feb 3, 2016 | 10:19 PM
tlambert's Avatar
2005 E55 AMG
Nice thread. My visors are coming apart. I'll check the rod now when I repair them.
Thanks for the post.
Old Feb 4, 2016 | 09:09 AM
thtguy's Avatar
2017 GLS 550
Yeah I should have taken more when I took the frame completely out. Not sure I am going to tear the driver side visor apart, since it isn't separating.
but if I do I will take more.
BTW... those frames are very sturdy, they have a metal wire about the size of a coat hanger molded into it all the way around. so I don't think you have to worry about breaking them if you try to work your visor to loosen it up.
