OEM NAV Install
I really dislike the little mickey mouse display that it currently has.
I want to know what I would need for the OEM Navi conversion, without actually hooking up the Navi. I just want the screen and the ability to play radio/CD's/Etc.... I find even in cars with Navigation I simply use the iPhone when I need directions.
Basically I want to know if I just buy the Head unit... will it bolt right in and work just like my current head unit works?
Any help is appreciated, thanks.
Emailed the seller asking if it will be direct bolt on. His response below:
"Yes direct Bolt on to w211 up to 2007 non optic system"
Just want to confirm that this will in fact work. My system is non-optic??
Remove the rear driver side door sill / trim / carpeting. you will see orange fiber optic cables.
If the Comand unit you are going to buy has a fiber optic connection in the back it will work on your car.
There are a couple of threads on here with 2.5 installs.
The improvements are tremendous, as you'd get Bluetooth calling, navigation, backup camera with moving guide lanes (guides curve to match steering wheel angle), music storage in the HDD enclosed in the head unit, SD card storage, and everything is integrated into the car (steering wheel controls, dash display shows navigation, etc).
Comand unit is in !
Everything works like a charm EXCEPT my Bluetooth no longer works....
I have the OEM Bluetooth puck.
Anyone care to shed some light on this?
Pic comparing the two units (Much better looking with the Navi unit...)
