Keyless go - push button start issue
Old Mar 14, 2016 | 12:25 PM
2BenzGarage's Avatar
2005 E55, 2010 E350
Push button start stopped working, no error messages etc., rest of keyless go functions are fine. Used the sticky on the topic to tear the shifter down, but the wire thats usually the issue isn't broken and the button itself functions fine when tested.
Kinda stumped here, what else could it be?
Old Mar 14, 2016 | 12:46 PM
hayseed's Avatar
04 e55
I went through that -- wire looked intact but it was broken below the insulation right at the area in the pictures that shows its broken,,, splice a piece in there and give it a try..
Old Mar 14, 2016 | 04:58 PM
ej20rich's Avatar
E55 AMG
is the button completely unresponsive? no accessory on with one click?
Old Mar 15, 2016 | 10:57 AM
Elhonaz's Avatar
W211 E55 2003
did you take it apart to see that the common where the wire breaks isnt broken? Take a little flathead screwdriver and carefully pry the chrome push button out of the shifter and remove the microswitch . It comes off and is easy to put back. use a little piece of electrical wire and jump the microswitch connections. If nothing happes then the wire is broken somewhere. If you have a multimeter you can check if the swith works
Old Mar 15, 2016 | 01:12 PM
Toadster's Avatar
2005 E55 AMG
mine is always a PITA - have had it replaced 2X and it still acts up - the techs even dissasembled the last time and cleaned the contacts out really well - still sucks
