Keyless Entry Primary door reprogram
2007 E63 Keyless Entry on Primary door does not work
The best thing to do is to use a DAS to check if the buttons/handle switches are detected in DAS.
If you do not have access to a MBSTAR/DAS, the best thing to do is remove the handle and measure the resistance across the connector pins. You should see ~300 Ohms and 475 ohms if you pull on the handle or pressing the lock button.
If you don't see these resistances, then most likely your handle is bad. It is a common issue that the drivers door will be the first one to fail since it is used most often. No programming is required. I fixed mine in the thread below:
https://mbworld.org/forums/w211-amg/...o-handles.html
