Fuel pump relay keeps breaking
hello every one / I hope someone can advise me..
a week ago my e55 03 wont start too work I had checked the fuel pump it wasn't working the relay went bad so i had too changed it and it started too work for 5 too 10 min and the relay pops aging I changed the relay for the 2nd time and the same scenario, I checked the fuel pumps directly after the relay break one of the pumps was hot, (I have no clue) probably the fuel pump going bad? and I don't want to change and spend that kinda money on something that may not be broken![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Anything else that can make the fuel pump relay go bad ?
If you have 2 pumps ,you can disconect the hot one , by removing the wires . Try the car again, it should start on one pump alone .But wont drive on low pressure. Just an idea and easy to try.
The following 2 users liked this post by optimusprime m1:
hesham78 (08-15-2020),
khalid janahi (03-28-2016)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
'99 and '05 E55 AMG
Clogged filter/regulator will cause the pumps to over-current to keep fuel pressure up which in turn melts the relay.
Try these threads:
https://mbworld.org/forums/w211-amg/...cements-2.html
https://mbworld.org/forums/w211-amg/...ng-my-car.html
Try these threads:
Try these threads:
Try these threads:
unfortunately Its the fuel pump can you advice me with a better fuel pump oem or after market
thanks..
