Got to the track this weekend
Old 04-06-2016, 01:17 AM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Saturday was my first chance to try out my winter mods at the strip. For reference, last year I was running Hoosier DOT Drag Radials, Long Tube Headers w/cats, and a PLM H/X. According to my logs, my ET would have been about 12.00 @ 116MPH with Saturday's weather.
This year's mods are: 77mm clutched SC pulley, 82mm TB, ECU & TCU tunes by Anthony Lawshee, plus new plugs and wires. I ran a best of 11.65 @ 120MPH. Those mods were good for about .35s and 4 MPH. I still have to add the meth kit and do some dyno-tuning and see if we can't crack the 11.50 barrier.
Minty Fresh (04-06-2016)
Old 04-06-2016, 01:31 AM
Hulk's Avatar
A Merc
What was the temp and da?
Old 04-06-2016, 01:39 AM
JoeJErnst's Avatar
65 degrees and 400ft.
Old 04-06-2016, 08:11 AM
Hulk's Avatar
A Merc
Starting iats and ending iats?
You can get 11.5 just by getting better da
Old 04-06-2016, 11:43 AM
JoeJErnst's Avatar
IATs were starting around 110 and ending around 160 for most of my runs. Here's a log from one of my later runs:
Old 04-07-2016, 01:11 AM
Ruthle55's Avatar
e55 amg
Get a better track prep. You'll go 11.4x with a better 60ft.
Old 04-07-2016, 07:25 AM
Hulk's Avatar
A Merc
Get an ice tank or killer chiller, your starting iats are too high and timing is getting pulled
sexyxe (04-07-2016)
Old 04-07-2016, 11:47 AM
JoeJErnst's Avatar
Meth kit gets installed this weekend. Dyno tune next week, then we'll see how she fares at the West Coast Shootout on the 16th.
Old 04-07-2016, 03:18 PM
sexyxe's Avatar
04 E55
Keep us (Im at least interested) in how you go with the water meth. I am fitting a kit too and want to use it purely for cooling as I see similar temps to you due to the ambient temps around home. I'm interested in seeing if there are any power 'gains' read:lost power regained, to be made.
Old 04-07-2016, 06:22 PM
DVC
DVC's Avatar
'06 E55 AMG
Nice job, Joe.
Do you have a similar log with the stock blower pulley?
Old 04-08-2016, 06:52 AM
99lightning's Avatar
99 ford lightning
air charge rise is pretty good on your car. My car all stock pulleys stock cooling with split and cobra tank 50 deg rise I would get I was able to cool mine starting at 62 deg. fabtech tank and plm heat exchanger now a 100 deg rise.
Old 04-08-2016, 09:47 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I'm very interested too.
Old 04-08-2016, 11:30 AM
JoeJErnst's Avatar
Originally Posted by DVC
Nice job, Joe.
It's hard to make a direct comparison because I changed more than just the pulley, and my old logs were taken during varying weather conditions.
In general, however, my IAT's last year (on a stock pulley) would rise about 35-40 deg. F. over the course of a 1/4 mile run. The three logs I have from this year (with a 77mm, 82mm TB, and ECU/TCU tunes) showed about a 50 deg F. rise.
I'll post more logs once I have the meth installed.
Old 04-08-2016, 10:10 PM
DVC
DVC's Avatar
'06 E55 AMG
Thanks! Good point. I was wondering if your boost was more stable with the stock pulley, or did it rise and fall like this log?
Old 04-09-2016, 12:01 AM
JoeJErnst's Avatar
Unfortunately I never logged boost last year so I don't know. I did notice how on my logs last weekend the boost was trailing off, so I ordered a new bearing for my BWK so I can put it back on. I'll see next week if it has any affect.
Old 04-09-2016, 03:38 PM
black06c230's Avatar
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
Killer Chiller + trunk tank + meth = WIN
In 80* weather would start at 55-60* and end no higher than 100*
Old 04-09-2016, 04:56 PM
C32owner's Avatar
2011 CL63 AMG (Current) 2005 CLS55 AMG (Current) 2004 C32 AMG (Sold)
Don't quite understand this one, can you elaborate more please. From what in understand your car staying stock pulleys except for cooling initially with split cooling system only had a 50deg rise, then you upgraded the cooling system to Plm heat exchanger and now you get a 100deg rise wtf
Old 04-09-2016, 05:06 PM
Hulk's Avatar
A Merc
His pump is most likely not drawing power on wot
Old 04-10-2016, 07:55 AM
99 ford lightning
i se 13.5 to 13.7 voltage when I step on it not sure what it should be and if that's causing the pump not to flow as much
Old 04-10-2016, 08:09 AM
Hulk's Avatar
A Merc
Something is not right with the pump, if you can swap out with another pump to see
Old 04-10-2016, 08:11 AM
99 ford lightning
yea that's the voltage on the aeorforce gauge not sure if the front battery being shot since I always get that red light I will prob get a pump and new front battery. prob wont get a chance to race to the fall anyway.
Old 04-11-2016, 01:23 AM
JoeJErnst's Avatar
I threw in the towel on the Meth install. I couldn't find anywhere except the trunk to mount the pump. I'm just going to make the best of it for the summer and do a KC and underhood tank next winter.
Old 04-11-2016, 02:45 AM
Ruthle55's Avatar
e55 amg
do some injectors and race gas.
Old 04-11-2016, 07:39 AM
sexyxe's Avatar
04 E55
What's wrong with mounting the pump in the trunk?
Old 04-11-2016, 09:06 AM
Hulk's Avatar
A Merc
You can mount the pump near the front bumper, I posted a pic awhile back
Quick Reply: Got to the track this weekend
