Got to the track this weekend
Old 04-11-2016, 11:23 AM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Originally Posted by JoeJErnst
I threw in the towel on the Meth install. I couldn't find anywhere except the trunk to mount the pump. I'm just going to make the best of it for the summer and do a KC and underhood tank next winter.
What happened with mounting it behind the fender liner?
Old 04-11-2016, 12:45 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
The Snow Performance pump I have must be bigger than others. I couldn't make it fit behind the fender liner or anywhere up near the front bumper. (I took the whole damn bumper off and still couldn't make it work.) I don't want to put it in the trunk because that's where I put my tires on track days, and the only place I could mount it while leaving room for the tires would interfere with the trunk floor.
I'll probably skip the meth as long as it's my DD. Once I don't have to haul groceries anymore then the trunk is fair game!
Old 04-11-2016, 12:59 PM
nanayaw6's Avatar
Oh bummer, that sucks with the pump man. I'm running the devils own pump and I think that's what Hulk might be running too.
Before you call it, how about one more place? Looking at the passenger side air intake pipe connecting the airbox to the radiator opening, you should see the frame of the car running just below that pipe. Is there enough space to mount the pump on that rail?
Old 04-11-2016, 01:05 PM
JoeJErnst's Avatar
I'll take a look before I throw in the towel. Thanks for the suggestion.
Old 04-11-2016, 01:25 PM
nanayaw6's Avatar
You're welcome, remove the intake pipe and get a good look/test fit.
Old 04-12-2016, 11:51 AM
djempirE55's Avatar
E55, Granturismo, F430, 993, E39, Jag
^^ trunk or bumper is best place. I chose the trunk on my previous car. Good luck on the pulls.
Old 04-12-2016, 01:04 PM
  #32
JoeJErnst's Avatar
Turns out that's where I tried putting it this weekend! I thought it would fit so I pulled the bumper to get access, but the headlight washer was in the way.
Old 04-13-2016, 03:12 PM
  #33
nanayaw6's Avatar
That snow performance pump must be huge then.
Old 04-13-2016, 08:13 PM
  #34
Rocman8's Avatar
E55
Originally Posted by 99lightning
air charge rise is pretty good on your car. My car all stock pulleys stock cooling with split and cobra tank 50 deg rise I would get I was able to cool mine starting at 62 deg. fabtech tank and plm heat exchanger now a 100 deg rise.
I've figured out this issue and posted in your thread. You have to make a pickup tube for this tank to work with this lid on it.
Old 04-14-2016, 05:03 AM
  #35
Super Moderator
BenzoBoi's Avatar
W221
Nice improvements!
Quick Reply: Got to the track this weekend
