Changed control arms, now steering wheel off. Normal?
Old Apr 16, 2016 | 12:16 PM
havok209's Avatar
'18 GLS 63
A few weeks ago I changed out the thrust arms and ball joints. The steering wheel remained centered. Yesterday I changed out the actual control arms and the steering wheel shifted to about the 1'o clock position with the wheels pointed forward. Is that normal? I have an appointment to have it aligned on Wednesday. Also, have new wheels coming that week. Should I have it aligned with OEM wheels then throw on the aftermarket ones or throw on the aftermarket ones and go to a top notch alignment shop?
Old Apr 16, 2016 | 01:11 PM
Rocman8's Avatar
E55
The camber probably changed slightly which will change your toe and cause the steering wheel to be off center. Alignment is always required after lower control arms. Also the control arm to the subframe is to be tightened once on the ground.
Old Apr 16, 2016 | 01:15 PM
havok209's Avatar
'18 GLS 63
Gotcha. I'll throw it on a drive on lift and loosen and retighten. Searched and searched but couldn't find anything on the control arms and not the thrust arms.
Old Apr 17, 2016 | 12:56 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
It doesn't matter which wheels you align it with
Old Apr 19, 2016 | 08:43 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
Different wheel offset/width can change many alignment angles.
Old Apr 19, 2016 | 08:57 PM
HeissRod's Avatar
Not enough to make any sort of difference.
